Zigbee Binding • Blue Series 2-1 Switch • SmartThings
REMINDER:  This switch is only to be used to control lights (except ballasts or any lights connected to a transformer). Do not use the switches on outlets, fans, or any other inductive load.
Below you'll find the instructions to setup Zigbee Binding (both individual and group) for the SmartThings platform using the Blue 2-1 Series switch.
Inovelli Box - Blue Series 2 in 1 (Transparent BG) - 1000px
DISCLAIMER
While we (and our community) try to keep these instructions up to date, it’s often hard due to the many updates to our firmware, SmartThings app & platform changes, as well as many other factors outside of our control. If any updates/edits need to be made to these instructions, please comment on this thread so we can keep it up-to-date:
COMMUNITY DRIVEN
Our entire Knowledge Base (which includes manuals) is community driven. This means that we at Inovelli work together with our amazing community to keep articles up-to-date. We’d love it if you’d contribute in any way you can, be it making edits, submitting how-to’s so others can learn, participating in our innovation projects, or simply commenting on threads. Thank you so much for your support and dedication to really making an impact in the smart home market.
NOTE: All of the pictures can be clicked on to be made larger. Also, if you’re on mobile, you can either click on the pictures or turn your phone side-ways and the pictures will become larger.
Please click on any of the sections in the Table of Contents to get started. We recommend working your way down as it follows an intentional flow that is user friendly and hub/gateway specific.   As always, any questions, please see the Additional Resources links section or submit a ticket, we’re happy to help.
Zigbee Binding Overview
Zigbee binding is when two or more Zigbee products communicate directly with one another without the need to communicate with a hub. There are two main benefits of utilizing Zigbee binding: speed & local control.
From a speed standpoint, cutting out the middle-man (hub) can save precious milliseconds or even seconds depending on your cloud and/or processing power off your hub. Whereas from a local control standpoint, if your hub goes does down and cannot communicate, your products can still talk to each other.
Below is a quick video that shows the speed of Zigbee Bindings:
NOTE: The above video is using Home Assistant via ZHA (however, the speed is identical using SmartThings).
Lastly, there are two different ways to setup Zigbee Binding: Individual and Group.
  1. Individual Binding: You are binding one Zigbee product to another
  2. Group Binding: You are binding one Zigbee product to a group of other Zigbee products (ie: used for 3+ bound devices)
There are two prerequisites to setting up Zigbee bindings with your Inovelli switch in SmartThings and they are:
* Ensure what you're binding to your switch is Zigbee and supports Zigbee binding
* Your Inovelli switch is using an Edge Driver
If you are binding a Blue Series Switch to a Philips Hue bulb, you will need the Hue bulb to be paired directly to the SmartThings hub (ie: it cannot be paired to the Philips Hue bridge). Zigbee bindings only work if each Zigbee device is on the same hub.
Compatible Products
We’ve tested Zigbee binding with the following Zigbee products on our switches:
Innr - A19 - RGBW
Philips Hue - A19 - RGBW
Philips Hue - BR30 - RGBW
Philips Hue - Play Bar - RGBW
Edge Driver Check
Before we get into setting up the bindings we need to make sure that your Inovelli switch is using the Inovelli Edge Driver (it should by default be picked up when you paired your device, just in case it hasn't we can check quickly). It will make it easier if the device you're binding to the Inovelli device is also using an Edge Driver, but it can be done without one.
The quick and easy way to determine whether or not your devices are using an Edge Driver is to do the following:
  1. Open up your SmartThings App and click on, "Devices" at the bottom
  2. Search for the device you want to check and click on it
  3. Click on the three dots at the top right and look to see whether or not it says, "Driver" (if it does, then your device is using an Edge Driver)
Edge Driver Installation
In an effort to keep directions consolidated into one area, please see the, " SmartThings Edge Driver Installation  page for instructions on how to install the Edge Driver for your Inovelli device.
For non-Inovelli devices, please reach out to SmartThings support, the device manufacturer, or comment in either the SmartThings or the Inovelli community for advice. As of January 2023, most devices have transitioned over to some sort of Edge Driver, but it's best to check with the manufacturer as to which Driver you should use.
Setup Instructions - Individual Bindings
We recommend individual bindings when there are only two devices being bound together. If you have more than two devices, please use group binding (if you can).
Unfortunately until Philips Hue gets an Edge Driver, you'll have to use Individual Bindings for 2+ devices and you may not have the best user experience depending on the size of your network (over 26 Zigbee devices).
Below we will walk through a couple different scenarios where you'd want to use Zigbee binding: Switch to Bulb and Switch to Switch.
Switch to Bulb(s)
Please select your scenario below. Remember, if you have more than two (2) Zigbee devices, we recommend Group Bindings for the best experience.
Philips Hue: Again, at this time, if you have Philips Hue, you will have to use individual bindings until they have an Edge Driver. Please select, "Smart Bulb is using a Device Handler (DTH)" in the instructions below.
Smart Bulb(s) Wired to Smart Switch
Please select from the following drop-downs based on the number of smart bulbs you have:
Smart Switch to 1x Smart Bulb
In this example, we will use the combination of Smart Bulb Mode (to keep full power to your smart bulbs) plus Zigbee Binding. Feel free to follow the written instructions below by clicking the drop downs:
Written Instructions
This part is broken into two sections: Getting the Zigbee ID and Zigbee Binding **Getting the Zigbee ID** In order to bind the Zigbee devices together, we need to identify which devices will be bound together. To do this, we need to get the Zigbee ID's. SmartThings does not have an easy way to do this, so apologies for the extra steps. In addition, there are two ways to accomplish this -- please select the dropdown that aligns to your situation. Remember to check first to see whether or not the smart bulb is using an Edge Driver or not (if the bulb does use an Edge Driver, please use the Edge Driver instructions -- if not, use the Device Handler instructions). Instructions to check are here: Edge Driver Check
Smart Bulb is using an Edge Driver
1. First, we'll need to create a SmartThings Access Token so that we can ultimately find the smart bulb(s) information -- head to the following link and login: [SmartThings Access Token]( https://account.smartthings.com/tokens/new)
Picture Visual
![SmartThings - Setting up Zigbee Bindings - Step 1A|690x1534, 50%](upload://wqd8aS8szrad1lM8Kq0S5VXAcpM.png)
2. Enter in a Token Name, select everything in the sections titled, "Devices" and "Locations" and then click, "Generate Token"
Picture Visual
![SmartThings - Setting up Zigbee Bindings - Step 2A|690x1640, 50%](upload://gD41LqJ5ENkWRriiSJGFIuW4PwC.png)
3. WRITE DOWN THE TOKEN AND SAVE IT!!! You will not be able to access this token again so you want to make sure you have it for future reference. Click on, "Copy token" move to Step 4.
Picture Visual
![SmartThings - Setting up Zigbee Bindings - Step 3A|690x1534, 50%](upload://6pZhK1xp8IUX0SVnP2o65mkK1mB.png)
4. Once you have the token saved in a secure place and copied to your clipboard, please go to the following URL, enter the access token and click, "Submit" (you should see your hub location and the various rooms you've created in the SmartThings app): https://lrmulli.github.io/st/index.html
Picture Visual
5. Find your device and click on the, "i"
Picture Visual
!![SmartThings - Setting up Zigbee Bindings - Step 5A|690x1101, 50%](upload://yxQY4mNG9lX9x7RiioetW75mSCZ.png)
6. Locate where it says, "eui" and copy the 16 digit code (Zigbee ID)
Picture Visual
![SmartThings - Setting up Zigbee Bindings - Step 6A|690x1534, 50%](upload://dj1f1VhepSSmo3EJj7MdxFm7Ujb.jpeg)
1. First, we'll need login to SmartThings IDE, which can be found here: [SmartThings IDE]( https://graph.api.smartthings.com/)
Picture Visual
![SmartThings - Setting up Zigbee Bindings - Step 1A - DTH|690x1534, 50%](upload://liaVXgw70KzBoK4Uwkl6YOni1Lb.png)
--- 2. Click on, "Devices" (if no devices show up, you may need to click on, "Locations" and then click on your Hub -- then click, "Devices"), find your device and click on it
Picture Visual
![SmartThings - Setting up Zigbee Bindings - Step 2A - DTH|690x1534, 50%](upload://gDBNIdFk391C125iIdFxPiPybeD.jpeg)
--- 3. Scroll to where it says, "Zigbee Id" and copy the ID (should be 16 characters)
Picture Visual
![SmartThings - Setting up Zigbee Bindings - Step 3A - DTH|690x1640, 50%](upload://y1lnzMMJbcCll9gc4AjQQdrXL8G.png)
**Zigbee Binding** Now we will bind your switch to your smart bulb. In this example, we will assume the smart bulb is the load on your smart switch (ie: the bulb socket is wired directly to your switch) -- and because of this assumption, we will also use Smart Bulb Mode (which provides constant power to your smart bulb and uses a digital signal to turn it on and off -- in this case Zigbee binding). Reminder: You need to have the Edge Driver installed on your Inovelli switch.
1. Open up your SmartThings app, and click on, "Devices"
Picture Visual
![SmartThings - Setting up Zigbee Bindings - Step 1B|690x1534, 50%](upload://unStxhnfvErritoIw8QfFymo6ez.jpeg)
--- 2. Locate your Inovelli switch and click on it
Picture Visual
![SmartThings - Setting up Zigbee Bindings - Step 2B|690x1534, 50%](upload://mpIdbLP69lHefu5ZhfGVpmOgy0S.jpeg)
--- 3. Click on the three dots at the top right and select, "Settings"
Picture Visual
![SmartThings - Setting up Zigbee Bindings - Step 3B|690x753](upload://xgyib2vJSwf23tfHpHCNeuVU06q.png)
--- 4. Scroll down to where it says, "52. Smart Bulb Mode" and select it
Picture Visual
![SmartThings - Setting up Zigbee Bindings - Smart Bulb Mode 1|690x1534, 50%](upload://nDkpTRmZ0uZr829wSty3XP5G8Os.png)
--- 5. Click on, "Smart Bulb Mode" and then "OK"
Picture Visual
![SmartThings - Setting up Zigbee Bindings - Smart Bulb Mode 2|690x1534, 50%](upload://WWaav4JCgqueQCVsfkAPbr3VF4.png)
--- 6. Scroll down to the bottom where it says, "Bind # 1, Bind #2, etc."
Picture Visual
--- 7. Click on, "Bind # X where X is the first available binding slot", enter in the device eui, a "/" slash, and the endpoint (exactly as shown in the example) , "Save"(for Philips Hue enter 11, for all others enter 1 -- if it doesn't work, please reach out to let us know the bulb make/model and we will try to figure out the endpoint)
Picture Visual
![image|338x725](upload://segdJzo1sfQKHnKTbCyLXb0AS09.png)
--- 8. Go back to the device page and then test your switch bindings. You should be able to tap up or down on the light switch and your smart bulb will turn on or off. In addition, you should be able to hold up or down to dim up or down the light bulb. If you'd like to control the colors from the switch (ie: double-tap to change the bulb to blue, triple-tap to change the bulb to red, etc), check out the instructions for [Scene Control]( https://community.inovelli.com/t/setup-instructions-blue-series-smart-2-1-switch-on-off-dimmer-smartthings/10365#scene-control-16).
Smart Switch to Multiple Smart Bulbs
This part is broken into two sections: Getting the Zigbee ID and Zigbee Binding **Getting the Zigbee ID** In order to bind the Zigbee devices together, we need to identify which devices will be bound together. To do this, we need to get the Zigbee ID's. SmartThings does not have an easy way to do this, so apologies for the extra steps. In addition, there are two ways to accomplish this -- please select the dropdown that aligns to your situation. Remember to check first to see whether or not the smart bulb is using an Edge Driver or not (if the bulb does use an Edge Driver, please use the Edge Driver instructions -- if not, use the Device Handler instructions). Instructions to check are here: [Edge Driver Check]( https://community.inovelli.com/t/how-tos-setup-zigbee-binding-smartthings/11940#edge-driver-check-5)
Picture Visual
--- 2. Enter in a Token Name, select everything in the sections titled, "Devices" and "Locations" and then click, "Generate Token"
Picture Visual
--- 3. WRITE DOWN THE TOKEN AND SAVE IT!!! You will not be able to access this token again so you want to make sure you have it for future reference. Click on, "Copy token" move to Step 4.
Picture Visual
--- 4. Once you have the token saved in a secure place and copied to your clipboard, please go to the following URL, enter the access token and click, "Submit" (you should see your hub location and the various rooms you've created in the SmartThings app): https://lrmulli.github.io/st/index.html
Picture Visual
--- 5. Find your device(s) and click on the, "i"
Picture Visual
--- 6. Locate where it says, "eui" and copy the 16 digit code (Zigbee ID)
Picture Visual
--- 7. Repeat steps 5-6 for each bulb you have and write down the Zigbee ID for each.
Picture Visual
Picture Visual
Picture Visual
--- 4. Repeat steps 2-3 for each bulb you have and write down the Zigbee ID for each.
**Zigbee Binding** Now we will bind your switch to your smart bulbs. In this example, we will assume the smart bulbs are on the load on your smart switch (ie: the bulb socket is wired directly to your switch) -- and because of this assumption, we will also use Smart Bulb Mode (which provides constant power to your smart bulb and uses a digital signal to turn it on and off -- in this case Zigbee binding). If your smart bulb(s) are not part of your switches load, you may skip steps 4-5. Reminder: You need to have the Edge Driver installed on your Inovelli switch.
Picture Visual
Picture Visual
Picture Visual
Picture Visual
Picture Visual
Picture Visual
Picture Visual
--- 9. Go back to the device page and then go back into Settings (Step 3) and follow steps 6-8 for each bulb you have (after each bulb, go back to the device page and then go back into "Settings". 10. Finally, test your switch bindings. You should be able to tap up or down on the light switch and your smart bulbs will turn on or off. In addition, you should be able to hold up or down to dim up or down the light bulbs. If you'd like to control the colors from the switch (ie: double-tap to change the bulb to blue, triple-tap to change the bulb to red, etc), check out the instructions for [Scene Control]( https://community.inovelli.com/t/setup-instructions-blue-series-smart-2-1-switch-on-off-dimmer-smartthings/10365#scene-control-16).
Smart Bulb(s) NOT Wired to Smart Switch
In this example, we will use Zigbee Binding to bind your switch to your smart bulb when your bulb is not the switches load (ie: the bulb socket is not wired directly to the switch). If your bulb socket is wired directly to your switch, please scroll up to the section titled, "Smart Bulb(s) Wired to Smart Switch" as you will need to use Smart Bulb Mode. Feel free to follow the written instructions below by clicking the drop downs:
Picture Visual
Picture Visual
Picture Visual
Picture Visual
--- 5. Find your device and click on the, "i"
Picture Visual
Picture Visual
Picture Visual
Picture Visual
Picture Visual
**Zigbee Binding** Now we will bind your switch to your smart bulb. In this example, we will assume the smart bulb is not the load on your smart switch (ie: the bulb socket is not wired directly to your switch) -- and because of this assumption, we will not use Smart Bulb Mode (which provides constant power to your smart bulb and uses a digital signal to turn it on and off -- in this case Zigbee binding). If your switch is wired directly to your smart bulbs, then please go to the section titled, "Smart Bulb(s) Wired to Smart Switch". Reminder: You need to have the Edge Driver installed on your Inovelli switch.
Picture Visual
Picture Visual
Picture Visual
--- 4. Scroll down to the bottom where it says, "Bind # 1, Bind #2, etc."
Picture Visual
--- 5. Click on, "Bind # X where X is the first available binding slot", enter in the device eui, a "/" slash, and the endpoint (exactly as shown in the example) , "Save"(for Philips Hue enter 11, for all others enter 1 -- if it doesn't work, please reach out to let us know the bulb make/model and we will try to figure out the endpoint)
Picture Visual
--- 6. Go back to the device page and then test your switch bindings. You should be able to tap up or down on the light switch and your smart bulb will turn on or off. In addition, you should be able to hold up or down to dim up or down the light bulb. If you'd like to control the colors from the switch (ie: double-tap to change the bulb to blue, triple-tap to change the bulb to red, etc), check out the instructions for [Scene Control]( https://community.inovelli.com/t/setup-instructions-blue-series-smart-2-1-switch-on-off-dimmer-smartthings/10365#scene-control-16).
In this example, we will use Zigbee Binding to bind your switch to your smart bulbs when your bulbs are not on the switches load (ie: the bulb socket is not wired directly to the switch). If your bulb sockets are wired directly to your switch, please scroll up to the section titled, "Smart Bulb(s) Wired to Smart Switch" as you will need to use Smart Bulb Mode. Feel free to follow the written instructions below by clicking the drop downs:
Picture Visual
Picture Visual
Picture Visual
Picture Visual
Picture Visual
Picture Visual
Picture Visual
Picture Visual
Picture Visual
**Zigbee Binding** Now we will bind your switch to your smart bulbs. In this example, we will assume the smart bulbs are not on the load on your smart switch (ie: the bulb sockets are not wired directly to your switch) -- and because of this assumption, we will not use Smart Bulb Mode (which provides constant power to your smart bulb and uses a digital signal to turn it on and off -- in this case Zigbee binding). If your smart bulbs are wired directly to the smart switch, please go to the section titled, "Smart Bulb(s) Wired to Smart Switch". Reminder: You need to have the Edge Driver installed on your Inovelli switch.
Picture Visual
Picture Visual
Picture Visual
Picture Visual
Picture Visual
--- 6. Go back to the device page and then go back into Settings (Step 3) and follow steps 4-5 for each bulb you have (after each bulb, go back to the device page and then go back into "Settings". 7. Finally, test your switch bindings. You should be able to tap up or down on the light switch and your smart bulbs will turn on or off. In addition, you should be able to hold up or down to dim up or down the light bulbs. If you'd like to control the colors from the switch (ie: double-tap to change the bulb to blue, triple-tap to change the bulb to red, etc), check out the instructions for [Scene Control]( https://community.inovelli.com/t/setup-instructions-blue-series-smart-2-1-switch-on-off-dimmer-smartthings/10365#scene-control-16).
Switch to Switch
Please select the dropdown below for instructions. If you have more than two (2) Inovelli Blue Series switches, we recommend Group Bindings for the best experience.
2x Smart Switches (ie: Switch to Switch)
1. First, we'll need to create a SmartThings Access Token so that we can ultimately find the smart switch(es) information -- head to the following link and login: [SmartThings Access Token]( https://account.smartthings.com/tokens/new)
Picture Visual
Picture Visual
Picture Visual
Picture Visual
Picture Visual
Picture Visual
--- 7. Repeat steps 5-6 for each switch you have and write down the Zigbee ID for each.
**Zigbee Binding** Now we will bind your switches together. Reminder: You need to have the Edge Driver installed on your Inovelli switches.
Picture Visual
--- 2. Locate your Inovelli switch (Switch #1) and click on it
Picture Visual
Picture Visual
Picture Visual
Picture Visual
--- 6. Go back to the device page and then go to Switch #2, click on Settings (Step 3) and follow steps 4-5 but this time in Step 6 enter in Switch #1's Zigbee ID and go back to the main menu when completed 7. Finally, test your switch bindings. You should be able to tap up or down on each light switch and the opposite switch will turn on or off. In addition, you should be able to hold up or down to dim up or down each switch while turning on your light(s) connected to them.
Setup Instructions - Group Binding
We recommend group bindings when there are more than two devices being bound together. If you have two devices, please use individual binding in the section above.
The concept of group bindings is to create a group of Zigbee devices (ie: bulbs or switches) and then bind your switch to the group.
Note: If you are binding a group of Inovelli switches together you can skip steps 1-5 and just do steps 6-8 for each switch you want in the group.
1. First, if you are binding to a group of bulbs, please install the Mariano SmartThings Edge driver named "Zigbee Light Multifunction Mc"
2. Next, apply that driver to your bulb if it doesn't get applied automatically during inclusion. Go to the bulb in the ST app, click in the upper right hand corner, select "Driver", and then "Select different driver".
3. Find the "Zigbee Light Multifunction Mc" driver and choose "Apply"
4. Now we can go into the device "Settings". This is done by clicking the upper right corner option and choosing: "Settings". Scroll down to the bottom until you find "Add Group Number".
5. Choose a group number that is unique that you have not used previously (if you are doing this more than once). It can be any number between 1-65535. In this example I have chosen 333.
6. At this point you can navigate back the Blue switch in ST, go to "Settings" and scroll down to the very bottom where it says "Group Bind #1". Enter the same group number you chose above. (or, if you are binding a group of Inovelli switches choose a unique group number for this group of switches).
7. At this point, if you are controlling a group of smart bulbs, you may want to change the device settings to "Smart Bulb Mode" and set it to a "Dimmer" if you want to be able to dim the group up and down.
8. That is it! You should now be able to control your bulbs in group #333 directly with the Inovelli switch. This "multicast" method of communication should be instant and very reliable.
Article Feedback
See a mistake or an article that's out of date? Please let us know! With hubs updating all the time, it's hard to keep up. But we're happy to update our articles when needed.
DISCLAIMER:   As an Amazon Associate Inovelli, LLC earns from qualifying purchases.
    • Setup Instructions • Blue Series Fan Switch • SmartThings
      ARTICLE UNDER CONSTRUCTION - WE ARE MOVING OUR KB FROM THE COMMUNITY BACK TO THE SUPPORT SITE. THANKS FOR YOUR PATIENCE. REMINDER: This switch is only to be used to control lights (except ballasts or any lights connected to a transformer). Do not use ...
    • Setup Instructions • Blue Series 2-1 Switch • SmartThings
      REMINDER: This switch is only to be used to control lights (except ballasts or any lights connected to a transformer). Do not use the switches on outlets, fans, or any other inductive load. This is the digital setup instructions for the Blue Series ...
    • Setup Instructions • Blue Series 2-1 Switch • Hubitat
    • Spec Sheet • Blue Series mmWave Switch
      NOTE: This page is under construction and is not to be used for product information at this time - for the most up to date information, please see the Product Page. The VZM32-SN Inovelli mmWave Switch (Red Series) is a Z-Wave enabled smart switch ...
    • Setup Instructions • Red Series 2-1 Switch • SmartThings
      ARTICLE UNDER CONSTRUCTION - WE ARE MOVING OUR KB FROM THE COMMUNITY BACK TO THE SUPPORT SITE. THANKS FOR YOUR PATIENCE. Setup Instructions Overview This is the digital setup instructions for the Blue Series Smart Fan Switch (On/Off or Dimmer) on the ...
