What's the Difference Between Red and Black Series Switches?
The main difference between our Red & Black Series switches is that the Red Series has everything the Black Series has, plus: Energy Monitoring, Scene Control, and LED Bar Notifications.
Red vs Black Series
Please see below for the main differences between the Red and Black Series Switches:
Smart Bulb Capability
Lastly, with most hubs, the Red Series works better with all types of smart bulbs as it can use scene control (which is not supported by the Black Series switches). All switches can work with Z-Wave bulbs via Association. For more info, please see our
Smart Bulb and Smart Switch Setup Guide (
NOTE: This is for SmartThings, but the logic applies to most hubs).
How To: Manually Program Your Dimmer Switch (Red & Black Series)
Overview This knowledge-base article will show you how to program your dimmer switch (both Red & Black Series) when you install it outside of a single-pole, neutral setup (ie: 3-Way, 4-Way, non-neutral, etc). This will have to be manually done as ...
Can I Install Multiple Smart Switches in a 3-Way, 4-Way, etc?
Summary (TLDR) You sure can, however, there are a few steps you should take to make the experience optimal. This is a great solution for people that want to use an alternative wiring scheme or want to have notifications and scene control at both ...
Spec Sheet | Dimmer - Black Series (Gen 2) | LZW31
What Inovelli Switches Can Be Used with Fans?
You can use the Black Series On/Off, Red Series On/Off and our Fan/Light Switch on ceiling or exhaust fans. The On/Off switches can only turn the fan on/off and require the fan to be no more than 300W inductive load, while the Fan/Light switch can ...
Installation & Setup | LZW30 | On/Off - Black Series (Gen 2) | Hubitat
This article will walk you through how to setup your Inovelli On/Off Switch (Black Series) from an in-wall installation to pairing it to your Hubitat Elevation Hub. For more advanced features such as Parameter Configuration and Device Handler ...
