What Inovelli Switches Can Be Used with Fans?
You can use the Black Series On/Off, Red Series On/Off and our Fan/Light Switch on ceiling or exhaust fans. The On/Off switches can only turn the fan on/off and require the fan to be no more than 300W inductive load, while the Fan/Light switch can provide 3-Speeds. No other Inovelli switch is rated for fans, so please do not use them otherwise you void the warranty and risk damage to your fan and/or switch.
NOTE: Please only use the above switches on ceiling or exhaust fans.
    • What's the Difference Between Red and Black Series Switches?
      Summary (TLDR) The main difference between our Red & Black Series switches is that the Red Series has everything the Black Series has, plus: Energy Monitoring, Scene Control, and LED Bar Notifications. Red vs Black Series Please see below for the ...
    • Wiring Diagrams for Ceiling Fan + Light Switch
      Overview These wiring diagrams should only be used for our fan & light switch and should not be used for anything other than a ceiling fan (ie: no exhaust fans). Pre-Requisites & Comments Neutral Wire is Required at both the switch and canopy ...
    • Installation & Setup | LZW30-SN | On/Off - Red Series (Gen 2) | SmartThings
      This article will walk you through how to setup your Inovelli On/Off Switch (Red Series) from an in-wall installation to pairing it to your Samsung SmartThings Hub. For more advanced features such as Parameter Configuration, Device Handler ...
    • Installation & Setup | LZW31-SN | Dimmer - Red Series (Gen 2) | Wink
      This article will walk you through how to setup your Inovelli Dimmer Switch (Black Series) from an in-wall installation to pairing it to your Wink Hub. For more advanced features such as Parameter Configuration please see the recommended articles ...
