Tap Settings Commands - Gen 1
Changing Setting at the Switch - Gen 1 - (NZW30, NZW30S, NZW30T, NZW31, NZW31S, NZW31T)
Below is a table of setting you can change by using the corresponding tap commands on the switch.
    • Spec Sheet | Dimmer - Toggle (Gen 1) | NZW31-T
      The NZW31-T Inovelli Dimmer Toggle Switch is a Z-Wave enabled smart switch that works with many different hubs and gateways and allows remote control from anywhere in the world. It touts many parameter configurations and allows for Z-Wave Scene ...
    • Spec Sheet | On/Off - Toggle (Gen 1) | NZW30-T
      The NZW30-T Inovelli On/Off Toggle Switch is a Z-Wave enabled smart switch that works with many different hubs and gateways and allows remote control from anywhere in the world. It touts many parameter configurations and allows for Z-Wave Scene ...
    • Button Combination Cheat Sheet | Fan + Light - Red Series (Gen 2) | LZW36
      Changing Settings at the Switch | Fan + Light - Red Series (Gen 2) | LZW36 Below is a table of setting you can change by using the corresponding tap commands on the switch.
    • Spec Sheet | Dimmer - Scenes (Gen 1) | NZW31-S
      The NZW31-S Inovelli Dimmer Switch is a Z-Wave enabled smart switch that works with many different hubs and gateways and allows remote control from anywhere in the world. It touts many parameter configurations and allows for Z-Wave Scene Control ...
    • Spec Sheet | On/Off - Scenes (Gen 1) | NZW30-S
