Device Handler Installation | LZW30 | On/Off - Black Series (Gen 2) | SmartThings
This article will walk you through the features of the custom device handler and how to install it for optimal usage and advanced functionality on your Inovelli Black Series On/Off (LZW30). We promise it's not hard and should take you 5-10 minutes tops.
  1. SmartThings IDE Tab Open: https://account.smartthings.com/ (sign in with the same info as you do with the app)
  2. Device Handler Code Tab Open: LZW30 Raw Code
About the Device Handler
Let's get this party started. The first step is to understand what functionality you'll gain by installing the device handler. Please see the parameter sheet to understand everything that is included with installation.
We recommend installing the device handler prior to installing your switch, but it really doesn't matter. There will just be a few additional steps you'll need to take if you install the handler after you install and pair your switch.
Installing the Code
  1. Open up IDE and go to "My Device Handlers"
  3. Next click on, "From Code"
  4. Now switch tabs and go to the LZW30 Raw Code link in GitHub
  9. Finally, click on, "Publish" and "For Me" and you're all set
NOTE: If you haven't paired your switch yet, feel free to install/pair it and the switch should automatically detect the device handler (the switch will show up as: Inovelli Switch). If you already paired your switch and/or it showed up as a, "Z-Wave Switch Secure" (or something like that), you'll have to associate the new handler to the switch. To do this, follow the directions below.
You'll only need to do this step if you already paired your switch or the switch is showing up as a, "Z-Wave Switch Secure" (or anything other than, "Inovelli Switch"). To do this do the following:
  1. In IDE, click on, "My Devices"
  2. Locate your Inovelli Black Series On/Off Switch and click on it
  3. Scroll to the bottom and click, "Edit"
  4. Scroll down about halfway where it says, "Type" and click on it (a dropdown will appear)
  5. In the dropdown, scroll down until you find, "Inovelli Switch LZW30" and select it
  6. Click, "Update" and you should be all set
Checking For Success
  1. Open up your SmartThings app
  2. Locate your Inovelli On/Off Switch and click on it
  3. Click on the three dots at the top right and select, "Settings"
  4. You should see a ton of options available to you now
