Spec Sheet • White Series Add-On (Aux) Switch
NOTE: This page is under construction and is not to be used for product information at this time - for the most up to date information, please see the
Product Page.
The Inovelli Add-On (Aux) Switch (White Series) is a "dumb" switch that works in conjunction with your Inovelli smart switch. This is not a smart switch.
Model #: AUX001 (White Series)
Years Produced: 2022+
Status: In Market
Important Docs:
Latest Firmware: N/A (not a smart switch)
- Multi-Tap: Multi-tap your aux switch with an Inovelli switch to activate scenes
- Accessories Included: Neutral Wire Jumper (Almond not included)
- Neutral Wire Required: No (but recommended)
- Leading/Trailing Edge: Leading & Trailing Edge
- Non-Neutral and 3-Way w/Dumb switch is Leading Edge only - all other configurations have the ability to be either Leading or Trailing Edge
- Max Wattage: TBD
- Min Wattage: If neutral wire is used, there is no minimum wattage required. However, if no neutral is installed, you will need a bypass
- Use with Fan: Yes, it can be used with an Inovelli Fan Switch
- UL Certified:
- FCC Certified:
- IC Certified:
Spec Sheet • Blue Series mmWave Switch
NOTE: This page is under construction and is not to be used for product information at this time - for the most up to date information, please see the Product Page. The VZM32-SN Inovelli mmWave Switch (Red Series) is a Z-Wave enabled smart switch ...
Spec Sheet • Red Series mmWave Switch
NOTE: This page is under construction and is not to be used for product information at this time - for the most up to date information, please see the Product Page. The VZW32-SN Inovelli mmWave Switch (Red Series) is a Z-Wave enabled smart switch ...
Zigbee Binding • Blue Series 2-1 Switch • SmartThings
REMINDER: This switch is only to be used to control lights (except ballasts or any lights connected to a transformer). Do not use the switches on outlets, fans, or any other inductive load. Below you'll find the instructions to setup Zigbee Binding ...
Setup Instructions • Blue Series Fan Switch • SmartThings
ARTICLE UNDER CONSTRUCTION - WE ARE MOVING OUR KB FROM THE COMMUNITY BACK TO THE SUPPORT SITE. THANKS FOR YOUR PATIENCE. REMINDER: This switch is only to be used to control lights (except ballasts or any lights connected to a transformer). Do not use ...
Setup Instructions • Blue Series 2-1 Switch • Hubitat
REMINDER: This switch is only to be used to control lights (except ballasts or any lights connected to a transformer). Do not use the switches on outlets, fans, or any other inductive load. This is the digital setup instructions for the Blue Series ...
