The LZW45 Inovelli RGBTW Smart LED Strip is the first Z-Wave enabled individually addressable lightstrip that works with many different hubs and gateways and allows remote control from anywhere in the world.
Make:
Inovelli
Model #:
LZW45
Generation:
First
Years Produced:
November 2020 - Present
Status:
In-Market
Kit Specs and Certifications
What's in the Box
- 5x - 1 foot LED Strips (w/adhesive tape on the back)
- 2x - 6 inch LED Strips (w/adhesive tape on the back)
- Z-Wave Controller
- Power Adapter
Specifications (Z-Wave Controller)
- Technology: Z-Wave Plus
- Z-Wave Chip: 700 Series
- Dimensions: Please see below diagram
- Dimensions for Included Power Bank: Cord is 10 feet long
Specifications (LED Strips)
Individually Addressable LED's: Yes
- LED Type:
Lightstrip (3x LED's per inch = 1x Pixel + 1x Warm White LED + 1x Cool White LED) = 24 LED's per foot
Pixel Type:
WS2815
Lumens:
1600 (6ft) or 267 lm/foot (lumens will drop after 16ft without an additional power source)
Color Range:
Full RGB (Red, Green, Blue) Color & and Tunable White
Temperature Range:
2700k to 6500k (Warm to Cold White)
CRI/Ra Value:
80
R9:
0
Wattage:
20W
Power:
120V AC, 60 Hz, 310mA
Operating Temperature:
32-104 °F (0-40 °C)
- Maximum Length (not including extension cords): 16 feet (future firmware updates will lengthen this)
Indoor/Outdoor Use:
Indoor use only.
ETL Listed:
5003280
FCC Certified:
2AB2QLZW45
IC Certified:
10256A-LZW45
Z-Wave Plus Certified:
In Progress
Note about IC:
IC site does not have a direct URL for devices -- it will take you to a search bar. Type the IC # in the, "Certification Number" section. Please see the PDF at the bottom of the article for a screenshot of the IC website.
Depending on the version, this lightstrip supports many advanced settings as shown below. Please reach out for the latest firmware file if you'd like to upgrade your firmware* (
NOTE:
this requires a special tool that needs to be purchased separately unless your Hub supports Over-the-Air upgrades).
NOTE: Click on the chart to make it larger if you can't read it.
Current Firmware Version:
1.19
Fibaro Home Center 2
Fibaro Home Center Lite
Home Assistant
HomeSeer
Hubitat
openHAB
Open Z-Wave
SmartThings
Zipato ZipaTile
If your hub is not listed above, please get in touch with us before buying the bulb to avoid the hassle of returns.
Smart speakers are NOT Z-Wave hubs so they won't work directly with any Z-Wave devices. But you can use a compatible Z-Wave hub with smart speaker integration to control your dimmer with voice control. These include the Fibaro hubs, Hubitat, SmartThings, and Wink.
