Inovelli Dimmer Switch (Toggle) - NZW30-T - Spec Sheet
Spec Sheet | On/Off - Toggle (Gen 1) | NZW30-T
The NZW30-T Inovelli On/Off Toggle Switch is a Z-Wave enabled smart switch that works with many different hubs and gateways and allows remote control from anywhere in the world. It touts many parameter configurations and allows for Z-Wave Scene Control directly from the switch.
Model #: NZW30-T
Generation: First
Years Produced: December 2017 - December 2018
Status: Discontinued
  1. Technology: Z-Wave Plus
  2. Z-Wave Chip: 500 Series
  3. 3-Way Compatibility: Works only with a dumb (existing) on/off switch (no dimming)
  4. 4-Way Compatibility: Works only with a dumb (existing) on/off switch (no dimming) and Line/Load must be in the same box
  5. Z-Wave Scene Enabled:  Add up to 12 Z-Wave Scenes (ie: multi-tap to trigger a scene/routine directly from the switch)
  6. Accessories Included: Neutral Wire Jumper
  1. Neutral Wire Required: Yes
  2. Max Wattage: 960W Incandescent, 150W LED and CFL bulbs, 1800W (15A) Resistive
  3. Power: 120V AC, 60 Hz
  4. Operating Temperature: 32-104 °F (0-40 °C)
  5. Signal Frequency: 908.42 MHz
  6. Range: Up to 100 meters line of sight between the Wireless Controller (Hub) and the closest Z-Wave Module
  7. Indoor/Outdoor Use: Indoor use only.
  8. Dimensions: See below (note picture is of the paddle version, but the dimensions are the same)
  1. UL Certified: E464831
  2. FCC Certified:  OXGZW31
  3. Z-Wave Plus Certified
  1. State After Power Restored: Switch will remember the last on/off and dim level prior to losing power
  2. Invert Switch: Inverts the switch (Tap Down = On, Tap Up = Off)
  3. Auto-Off Timer: Automatically turns the switch off after x seconds
  4. Disable/Invert LED: LED can be disabled or inverted
Please see the, "Tap Sequence & Parameter Document" at the bottom of the page for more information.
  1. 2GIG (no advanced settings)
  2. ADT Pulse (no advanced settings)
  3. Alarm.com (no advanced settings)
  4. Almond (Securify) (no advanced settings)
  5. Fibaro Home Center 2
  6. Fibaro Home Center Lite
  7. Home Assistant
  8. HomeSeer
  9. Hubitat
  10. InControl
  11. Indigo
  12. ISY
  13. openHAB
  14. Open Z-Wave
  15. Piper (no advanced settings)
  16. Ring (no advanced settings)
  17. SmartThings Hub
  18. Staples Connect DLink (no advanced settings)
  19. VeraEdge
  20. VeraLite
  21. VeraPlus
  22. VeraSecure
  23. Wink and Wink 2 (no advanced settings)
  24. Zipato ZipaTile
These switches should also be recognized by any open systems that support on/off (binary switch) device types. If your hub is not listed above, please get in touch with us before buying the switch to avoid the hassle of returns.
    • Spec Sheet | Dimmer - Toggle (Gen 1) | NZW31-T
      The NZW31-T Inovelli Dimmer Toggle Switch is a Z-Wave enabled smart switch that works with many different hubs and gateways and allows remote control from anywhere in the world. It touts many parameter configurations and allows for Z-Wave Scene ...
    • Spec Sheet | Dimmer - Black Series (Gen 2) | LZW31
    • Spec Sheet | Dimmer (Gen 1) | NZW31
      The NZW31 Inovelli Dimmer Switch is a Z-Wave enabled smart switch that works with many different hubs and gateways and allows remote control from anywhere in the world. Overview Make: Inovelli Model #: NZW31 Generation: First (Predecessor To: Second ...
    • Spec Sheet | On/Off - (Gen 1) | NZW30
      The NZW30 Inovelli On/Off Switch is a Z-Wave enabled smart switch that works with many different hubs and gateways and allows remote control from anywhere in the world. Overview Make: Inovelli Model #: NZW30 Generation: First (Predecessor To: Second ...
