The NZW30 Inovelli On/Off Switch is a Z-Wave enabled smart switch that works with many different hubs and gateways and allows remote control from anywhere in the world.
Model #: NZW30
Years Produced: December 2017 - December 2018
Status: Discontinued
- Technology: Z-Wave Plus
- Z-Wave Chip: 500 Series
- 3-Way Compatibility: Works only with a dumb (existing) on/off switch (no dimming)
- 4-Way Compatibility: Works only with a dumb (existing) on/off switch (no dimming) and Line/Load must be in the same box
- Accessories Included: White & Almond Faceplates/Paddles and a Neutral Wire Jumper
- Neutral Wire Required: Yes
- Max Wattage: 960W Incandescent, 150W LED and CFL bulbs, 1800W (15A) Resistive
Dimensions: See below
- UL Certified: E464831
- FCC Certified: OXGZW31
- Z-Wave Plus Certified
- Disable/Invert LED: LED can be disabled or inverted
Please see the, "Tap Sequence & Parameter Document" at the bottom of the page for more information.
- 2GIG (no advanced settings)
- ADT Pulse (no advanced settings)
- Alarm.com (no advanced settings)
- Almond (Securify)
- InControl
- Indigo
- ISY
- openHAB
- Open Z-Wave
- Piper (no advanced settings)
- Ring (no advanced settings)
- SmartThings Hub
- Staples Connect DLink (no advanced settings)
- VeraEdge
- VeraLite
- VeraPlus
- VeraSecure
- Wink and Wink 2 (no advanced settings)
These switches should also be recognized by any open systems that support on/off (binary switch) device types. If your hub is not listed above, please get in touch with us before buying the switch to avoid the hassle of returns.
