The NZW31-S Inovelli Dimmer Switch is a Z-Wave enabled smart switch that works with many different hubs and gateways and allows remote control from anywhere in the world. It touts many parameter configurations and allows for Z-Wave Scene Control directly from the switch.
Model #: NZW31-SN
Years Produced: December 2017 - December 2018
- Technology: Z-Wave Plus
- Z-Wave Chip: 500 Series
- 3-Way Compatibility: Works only with a dumb (existing) on/off switch (no dimming)
- 4-Way Compatibility: Works only with a dumb (existing) on/off switch (no dimming) and Line/Load must be in the same box
- Z-Wave Scene Enabled: Add up to 10 Z-Wave Scenes (ie: multi-tap to trigger a scene/routine directly from the switch)
- Accessories Included: White & Almond Faceplates/Paddles and a Neutral Wire Jumper
- Neutral Wire Required: Yes
- Max Wattage: See below -- maximum will vary based on bulb type and whether the heat sink tabs are removed or not
- Heat Sink Tabs Not Removed: 500W Incandescent, 150W LED
- One (1) Side Heat Sink Tabs Removed: 400W Incandescent, 150W LED
- Two (2) Sides Heat Sink Tabs Removed: 300W Incandescent, 150W LED
Dimensions: See below
- UL Certified: E464831
- FCC Certified: OXGZW31
- Z-Wave Plus Certified
- Ramp Rate: How fast or slow the light turns dim when you adjust the switch remotely
- Minimum Dim Level: Minimum level the light switch will dim to
- Disable/Invert LED: LED can be disabled or inverted
Please see the, "Tap Sequence & Parameter Document" at the bottom of the page for more information.
- 2GIG (no advanced settings)
- ADT Pulse (no advanced settings)
- Alarm.com (no advanced settings)
- Almond (Securify) (no advanced settings)
- InControl
- Indigo
- ISY
- openHAB
- Open Z-Wave
- Piper (no advanced settings)
- Ring (no advanced settings)
- SmartThings Hub
- Staples Connect DLink (no advanced settings)
- VeraEdge
- VeraLite
- VeraPlus
- VeraSecure
- Wink and Wink 2 (no advanced settings)
These switches should also be recognized by any open systems that support on/off (binary switch) device types. If your hub is not listed above, please get in touch with us before buying the switch to avoid the hassle of returns.
