SmartThings Device Handlers
Device Handler Locations
Please see the following locations for each Inovelli Device Handler. Then follow the instructions below!
Switches
  1. LZW30 - On/Off (Black Series) - Gen 2
  2. LZW30-SN - On/Off (Red Series) - Gen 2
  3. LZW31 - Dimmer (Black Series) - Gen 2
  4. LZW31-SN - Dimmer (Red Series) - Gen 2
  5. LZW36 - Fan/Light (Red Series)*
  6. NZW30 - On/Off Switch - Gen 1 - Discontinued
  7. NZW30-S - On/Off Switch w/Scenes - Gen 1 - Discontinued
  8. NZW30-T - On/Off Toggle Switch w/Scenes - Gen 1 - Discontinued
  9. NZW31 - Dimmer Switch - Gen 1 - Discontinued
  10. NZW31-S - Dimmer Switch w/Scenes - Gen 1 - Discontinued
  11. NZW31-T - Dimmer Toggle Switch w/Scenes - Gen 1 - Discontinued
Bulbs/Strips
  1. LZW41 - CCT (Tunable White) A19 Bulb
  2. LZW42 - RGBW (Multi-Color) A19 Bulb
  3. LZW45 - RGBCCT Lightstrip & Controller Kit
Sensors
  1. LZW60 - 4-1 Multi-Sensor
Plugs (Indoor/Outdoor)
  1. NZW36 - Indoor 1-Channel On/Off - Discontinued
  2. NZW37 - Indoor 2-Channel On/Off - Discontinued**
  3. NZW39 - Indoor 1-Channel Dimmer - Discontinued
  4. NZW96 - Outdoor 1-Channel On/Off - Discontinued
  5. NZW97 - Outdoor 2-Channel On/Off - Discontinued**
*  Fan/Light Switch - You'll need to install the Switch Level Child Device Handler
** 2-Channel Smart Plugs - You'll need to install the Switch Child Device Handler
Driver Installation Instructions
Please follow the instructions below to install your Inovelli SmartThings Device Handler(s).
  1. Open up IDE and go to “My Device Handlers”
  2. Then click on, “Create New Device Handler”
  3. Next click on, “From Code”
  4. Now switch tabs and go to the device handler link in GitHub (shown above)
  6. Go back to the IDE tab (where you’re at the, “For Code” tab) and paste the code into the white box
  7. Scroll to the bottom of the page and click, “Create”
  8. Then on the next page, click, “Save”
  9. Finally, click on, “Publish” and “For Me” and you’re all set
