Setup Instructions • Blue Series Fan Switch • SmartThings
ARTICLE UNDER CONSTRUCTION - WE ARE MOVING OUR KB FROM THE COMMUNITY BACK TO THE SUPPORT SITE. THANKS FOR YOUR PATIENCE.
REMINDER:
This switch is only to be used to control lights (except ballasts or any lights connected to a transformer). Do not use the switches on outlets, fans, or any other inductive load.
This is the digital setup instructions for the Blue Series Fan Switch (Ceiling or Exhaust) on the SmartThings platform.
Navigating the Instructions
Please click on any of the sections in the Table of Contents to get started. We recommend working your way down as it follows an intentional flow that is user friendly and hub/gateway specific.
As always, any questions, please see the Additional Resources links section or submit a ticket, we’re happy to help.
Quick Setup Instructions
Follow these if you have already installed the Fan switch before and are just looking for some quick pairing instructions. If this is your first time installing the Fan switch, please skip this section and work your way through the various sections below starting with the Prerequisites.
This section assumes the following:
You’ve installed the Edge Driver
You’ve wired the switch and it works manually
Let’s begin:
Make sure your switch LED is pulsing blue – if it’s not, hold down on the configuration button (located at the top right of the switch above the LED bar) and then the top of the paddle (ie: the on portion) for approximately 20 seconds until it turns/flashes red – then release the config button followed by the top of the paddle and wait a couple seconds
With your LED pulsing blue, open up your SmartThings App to the, “Devices” tab and click on the + at the top right
Click, “Add Device”
Then under, “Scan for nearby devices” click, “Scan”
SmartThings should then search for, find and initialize the switch
The only prerequisite to pairing this switch is the following:
Installation of the Device Edge Driver
While this switch will also pair without it, for full functionality, you’ll want to install the Edge Driver.
Device Edge Driver Installation
To install the Edge Driver, please follow the instructions below:
Click on the following link
Samsung Edge Driver Access
and sign into your Samsung account (you may have 2-Factor Authentication on – if so, please follow the directions Samsung gives you to attain a code)
Next, click, “Enroll” by the hub your devices are paired to
Next, click, “Available Drivers”
Finally, click on the driver you’d like installed by clicking, “Install” (NOTE: In this case, please install, “Inovelli 2-in-1 Blue Series”)
Now when you pair your switch, it should automatically pick up the Edge Driver. Feel free to move onto the next section of the Setup Instructions below.
Installation Instructions
Various steps of the installation instructions can be found by clicking the links below. The reason they are not listed here is to save space and to only have one area that requires updating (rather than multiple locations with the same data).
Please follow both steps below (Wiring & Pre-Programming) before making your way to the
Pairing Instructions
1. Wiring Your Switch
Full Instructions
(Recommended if not familiar with schematics and/or this is your first time setting up this switch)
Schematics
(skip directly to reading the schematics)
2. Pre-Programming
Full Instructions
(Recommended if this is the first time installing this switch – NOTE: This is only needed if using the switch as a dimmer and/or multi-way setup)
The below instructions assume you have installed the Edge Driver prior to pairing.
1. Initiate Pairing on the Switch
There are two methods to pairing your switch to your hub/gateway: Auto-Pairing (default) and Manual-Pairing (Config Button press/hold method). Auto-Pairing begins when you restore power to your switch and eventually times out (the LED bar will pulse blue indicating it's in pairing mode and then stop when it's not). If your switch is not pulsing blue, please select, "Manual Pairing" to initiate the pairing process.
Auto-Pairing (Default)
When power is restored to the switch, it will automatically start the pairing process (LED Bar (C) should start pulsing blue).
Video Visual
Manual-Pairing (Config Button - Hold)
Once your LED Bar is pulsing blue, move on to the step below.
2. Initiate Pairing on the Hub
After you've initiated pairing on your switch, the LED bar should be pulsing blue.
If it's not pulsing, please hold down the config button followed by the top of the paddle for 20 seconds until the LED bar turns/flashes red (click below for a visual) -- then let go of the config button followed by the top of the paddle.
Visual
Feel free to follow the written instructions below by clicking the drop down or follow along with the video below:
Written Instructions
1. Open your SmartThings App and go to the, "Devices" tab
Picture Visual
2. Press the (+) button at the top right of the screen
Picture Visual
3. Click on, “Add Device”
Picture Visual
4. Under the, "Scan for nearby devices" section, click, “Scan” and your hub will search for devices
Picture Visual
5. If successful, the LED bar will turn green (if unsuccessful, the LED bar will turn red)
GIF Visual
6. In addition, your app will show your switch (likely called, "Inovelli 2-in-1 Blue Series" or something similar)
Picture Visual
7. Press the back arrow at the top of the screen to go back to the main menu
Picture Visual
8. Next, click on the, “Devices” tab and look for your switch – it should show up under, “No room assigned”
Picture Visual
9. Feel free to rename it and assign it to the proper room (to do this click on the switch, then click on the three dots and select, “Edit”)
Picture Visual
Once your switch is successfully paired, check to make sure you have basic functionality of your switch by turning it on/off (and if you have it as a dimmer, test the dimming) in the app.
If successful, we can move onto customizing your switch and setting up some advanced features (animations, scene control, etc) in the next section.
Advanced Feature Setup
This switch is packed with features and most of them come directly from this community. They've been debated back and forth, added to wishlists, and talked about over the course of 3+ years (as this switch builds on our Red Series lineup). Below we will explain all the parameters and show you how to change them from within SmartThings and then we'll go into some of the advanced features and explain how to set them up in SmartThings. If you have any questions along the way, feel free to create a post as there are many SmartThings users here who are excited to help.
Parameter Explanations
You will need to install an Edge Driver prior to accessing any of these features from within the app. Instructions can be found here:
A parameter is a setting within the switch firmware that allows you to change how the switch operates. For example, you want to change how fast your lights dim on and off, the color of the LED bar, minimum dimming level and much more -- all with a few clicks within the app.
The video below will show you how to access the parameters once the device handler is installed.
For a list of the most up-to-date parameters and the firmware version they are associated with, please visit our GitHub page
Animated Notifications
Animated notifications are used when you want to have a visual cue on your LED bar notify you of a certain event. A few examples would be:
* LED Bar pulses purple if your garage door is left open past 9pm
* LED Bar chases red if your front door is unlocked
* LED Bar fast blinks orange if a door is opened at night time
These notifications are accomplished by using, "Routines" within the SmartThings App. In this example, we'll setup a simple notification that alerts you if a door is opened between the hours of 9pm and 7am.
1. Open your SmartThings App and click on the, "Automations" icon at the bottom
Picture Visual
2. Click on the, "+" button at the top of the screen and select, "Create routine"
Picture Visual
3. Under the, "If" section, click on the, "+ Add what will trigger this routine" button
Picture Visual
4. Click on, "Device status" and find your contact sensor to click on
Picture Visual
5. This part may vary depending on your contact sensor, but the important thing is to select, "Contact sensor" and then, "Open" -- then click, "Done"
Picture Visual
6. Now, we'll add another condition to set a time value (ie: we only want this notification to run between the hours of 9pm and 7am) -- Click on, "+ Add Condition"
Picture Visual
7. Click on, "Time"
Picture Visual
8. Select, "Period of time" and then adjust where it says, "Start time" and "End time" and set those values to 9pm and 7am (then select the days you want this to be applicable and select, "Done")
Picture Visual
9. Under the, "Then" section, click on the, "+ Add what this routine will do" button
Picture Visual
10. Click on, "Control devices"
Picture Visual
11. Find your Inovelli Blue Series Fan Switch and click on it, then select, "Next"
Picture Visual
12. If, "Turn on" or "Turn off" is selected, click on it again to unselect it
Picture Visual
13. Select the Notification Effect, Notification Color, Notification Level and Notification Duration by pressing each button (in this case, we selected: Fast Blink, Orange, 100 (%), and Indefinitely) -- click, "Done"
Picture Visual
14. Ensure the correct notification values are selected, click, "Save" and name your routine
Picture Visual
15. Test your routine (to manually clear the notification, double-tap the config/favorites button)
Scene Control
Scene control, in this context, refers to activating a scene from your light switch via a tap sequence (ie: double-tap, triple-tap, favorites button, etc). This is not to be confused with setting up scenes in your SmartThings app, which is different.
In the below example, we will create a simple scene of turning on movie lights and setting them to blue at 80% with a double-tap up of the light switch. Feel free to follow the written instructions below by clicking the drop down or follow along with the video below:
1. Open your SmartThings App and go to the, "Automations" tab
Picture Visual
Picture Visual
Picture Visual
4. Click on, "Device status" and find your Inovelli Blue Series Fan Switch to click on
Picture Visual
5. Scroll to the section that says, "Up Button" and click on, "Pressed 2 times" followed by, "Done" (NOTE: If you want something other than double-tap up, please select a different sequence)
Picture Visual
6. Under the, "Then" section, click on the, "+ Add what this routine will do" button
Picture Visual
7. Click on, "Control devices"
Picture Visual
8. Select the movie lights you want to turn on and click, "Next"
Picture Visual
9. Then go through each light and click on, "Choose what you want this device to do"
Picture Visual
10. Click on, "Turn On", followed by, "Dimmer" (set it to 80%), and, "Color control" (select blue) -- then click, "Done"
Picture Visual
11. Ensure the correct status, color and level values are selected, click, "Save" and name your routine
Picture Visual
12. Test your routine by double tapping up on your Inovelli Blue Series Fan Switch and see if your movie lights turn on
Smart Bulb Mode
Using Zigbee Bulbs
The best method to have your smart switch work with Zigbee smart bulbs is to use Zigbee binding. If your Zigbee bulb does not support Zigbee binding (or your bulb isn't Zigbee), please follow the instructions in the
Using Non-Zigbee Bulbs
section.
See a mistake or an article that's out of date? Please let us know! With hubs updating all the time, it's hard to keep up. But we're happy to update our articles when needed.
DISCLAIMER:
As an Amazon Associate Inovelli, LLC earns from qualifying purchases.
REMINDER: This switch is only to be used to control lights (except ballasts or any lights connected to a transformer). Do not use the switches on outlets, fans, or any other inductive load. This is the digital setup instructions for the Blue Series ...
REMINDER: This switch is only to be used to control lights (except ballasts or any lights connected to a transformer). Do not use the switches on outlets, fans, or any other inductive load. Below you'll find the instructions to setup Zigbee Binding ...
ARTICLE UNDER CONSTRUCTION - WE ARE MOVING OUR KB FROM THE COMMUNITY BACK TO THE SUPPORT SITE. THANKS FOR YOUR PATIENCE. Setup Instructions Overview This is the digital setup instructions for the Blue Series Smart Fan Switch (On/Off or Dimmer) on the ...
