Click on "Devices" and then "+ Add Device" to start the process of adding your device to the network.
Scroll down and choose "Generic Z-Wave device".
Click through the prompts until you get to the screen that says "Follow the inclusion process as described in the users manual".
At this point you can turn the bulb off and then back on from the switch. Vera should eventually show a spinning wheel and proceed onto the next step.
Choose a name for your device and a room if you desire. Click "finish" to proceed.
Finally, the device will show up in your devices list and the inclusion is complete!
If for some reason the switch is not including, first make sure you are within range. Next, try an exclusion of the device before trying an inclusion. For an exclusion, the steps are the same as above except that during inclusion, Vera will suggest to try an exclusion if it detects a problem (after you hit "Retry" when the inclusion timer times out). After the removal process begins, turn the bulb off and then back on from the switch. After the exclusion is complete, you can proceed with the inclusion as stated in these instructions.
Summary (TLDR) Please see below for basic inclusion/exclusion information around the LZW41 - CCT (Tunable White) A19 Bulb. For more hub/gateway specialized instructions, please click on the URL's in the third section below to be taken to the specific ...
NOTE: As of January 2020, you will no longer need to install the device handler for this product to work as it's WWST (Works With SmartThings) Certified. However, if you'd like some additional functionality, please feel free to install the device ...
The LZW41 Inovelli CCT (Tunable White) Smart Bulb is a Z-Wave enabled light bulb that works with many different hubs and gateways and allows remote control from anywhere in the world. Overview Make: Ilumin (Powered by Inovelli) Model #: LZW41 Project ...
This article will walk you through how to setup your Ilumin CCT (Tunable White) A19 bulb using the Hubitat Elevation hub. Spec Sheet Prerequisites Device Driver Installed: Please have the LZW41 Device Driver installed prior to pairing/including ...
This article will walk you through how to setup your Ilumin (Inovelli) tunable white smart bulb with your Samsung SmartThings Hub. For more advanced features such as Device Handler Installation, please see the recommended articles below. Spec Sheet ...
