The LZW30 Inovelli On/Off Switch (Black Series) is a Z-Wave enabled smart switch that works with many different hubs and gateways and allows remote control from anywhere in the world.
Model #: LZW30 (Black Series)
Project Code Name: Knight Flank
Years Produced: September 2019 - Present
- Technology: Z-Wave Plus, S2 Encryption, SmartStart
- Z-Wave Chip: 500 Series
- 3-Way, 4-Way (Multi-Switch) Compatibility: Works with a dumb (existing) on/off switch (no dimming), auxiliary switch (GE or HomeSeer), or another Inovelli smart switch (via Z-Wave Association)
- Disable Internal Relay: Tap 8x on the config button to disable the internal relay
- Change Parameters Locally: Change parameters directly from the switch without the need for a Hub
- Accessories Included: White Faceplates/Paddles and a Neutral Wire Jumper (Almond not included)
- Neutral Wire Required: Yes
- Max Wattage: 600W Incandescent, 300W LED, 150W CFL, 1200W Resistive
- Min Wattage: None
- Use with Fan: Yes -- 300W Maximum (Inductive Load)
- UL Certified: E508406
- FCC Certified: 2AB2QLZW30
- IC Certified: 10256A-LZW30
- Z-Wave Plus Certified: ZC10-19086701
Note about UL and IC:
- UL site requires a purchase to view the certification. Please see the PDF at the bottom of the article for UL records.
- IC site does not have a direct URL for devices -- it will take you to a search bar. Type the IC # in the, "Certification Number" section. Please see the PDF at the bottom of the article for a screenshot of the IC website.
- LED Indicator Color: This will set the default color of the LED Bar
- LED Indicator Intensity: This will set the intensity of the LED Bar (ie: how bright it is)
- LED Indicator Intensity (When Off): This is the intensity of the LED bar when the switch is off
- 2GIG (no advanced settings)
- ADT Pulse (no advanced settings)
- Alarm.com (no advanced settings)
- Almond (Securify) (no advanced settings)
- EZLO (no advanced settings)
- InControl
- Indigo
- ISY (Only ISY994iZW +/IR-PRO -- DOES not work with ISY-994i)
- openHAB
- Open Z-Wave
- Piper (no advanced settings)
- Ring (no advanced settings)
- SmartThings Hub
- Staples Connect DLink (no advanced settings)
- Vivint Skycontrol (no advanced settings)
- Wink and Wink 2 (no advanced settings)
These switches should also be recognized by any open systems that support on/off (binary switch) device types. If your hub is not listed above, please
get in touch with us before buying the switch to avoid the hassle of returns.
