The LZW36 Inovelli Fan + Light Switch (Red Series) is a Z-Wave enabled smart switch that works with many different hubs and gateways and allows remote control from anywhere in the world. It touts a ton of features including energy monitoring, RGB notifications, Z-Wave scene control, configuration from the switch itself, and individual control of the both the fan motor and fan light.
Model #: LZW36 (Red Series)
Project Code Name: Hurricane
Generation: First
Years Produced: Launched 5/25/2020
Status: Current Generation
- Technology: Z-Wave Plus, S2 Encryption, SmartStart
- Z-Wave Chip: 700 Series
- 3-Way, 4-Way (Multi-Switch) Compatibility: Does not work in a 3-Way or Multi-Switch setting (we will launch a remote to solve this)
- Energy Monitoring: Monitors energy consumption (monitors light and fan separately)
- Z-Wave Scene Enabled: Add up to 42 Z-Wave Scenes (ie: multi-tap to trigger a scene/routine directly from the switch)
- RGB Notifications: 2x LED bars will notify you of certain events (ie: LED bar lights up red when front door is unlocked)
- Disable Internal Relay: Ability to disable the fan and/or light relay
- Change Parameters Locally: Change parameters directly from the switch without the need for a Hub
- Accessories Included: White Faceplates/Paddles and a Neutral Wire Jumper (Almond not included)
- Neutral Wire Required: Yes
- Max Horsepower (Fan): 1/6 HP
- Max Wattage (Lights): 200W Incandescent or 100W CFL/LED
- AC/DC Motor Compatibility: Only compatible with AC Motors
- UL Certified: E513509
- FCC Certified: 2AB2QLZW36-S
- IC Certified: 10256A-LZW36S
- Z-Wave Plus Certified: Yes
Note about UL and IC:
- UL site requires a purchase to view the certification. Please see the PDF at the bottom of the article for UL records.
- IC site does not have a direct URL for devices -- it will take you to a search bar. Type the IC # in the, "Certification Number" section. Please see the PDF at the bottom of the article for a screenshot of the IC website.
NOTE: To adjust the animations on a controller that does not have a device handler/driver, please use the values found on this site:
http://calculator.inovelli.com (click on the, "Notifications" tab and select the one you'd like -- then select the, "Configuration Value")
Light Parameters
- Dimming Speed: How fast or slow the light turns on (or dims) when you hold the switch (ie: dimming from 10-20%, 80-60%, etc)
- Dimming Speed (Z-Wave): How fast or slow the light turns on (or dims) when you adjust the switch remotely (ie: dimming from 10-20%, 80-60%, etc)
- Ramp Rate: How fast or slow the light turns on when you press the switch 1x to bring from On to Off or Off to On
- Ramp Rate (Z-Wave): How fast or slow the light turns on when you bring your switch from On to Off or Off to On remotely
- Minimum Dim Level: Minimum level the light switch will dim to
- Maximum Dim Level: Maximum level the switch will dim to
- Default Level (Local): Default dim level for the switch when pressed locally (at the switch)
- Default Level (Z-Wave): Default dim level for the switch when powered on via a Z-Wave command
- LED Indicator Color: This will set the default color of the LED Bar
- LED Indicator Intensity: This will set the intensity of the LED Bar (ie: how bright it is)
- LED Indicator Intensity (When Off): This is the intensity of the LED bar when the switch is off
- LED Strip Effect: This will allow you to add some sweet effects to your LED bar (ie: pulse, chase, solid, etc)
- LED Indicator Timeout: Changes the amount of time the RGB Bar shows the dim level if the LED Bar has been disabled
- Active Power Reports: The power level change that will result in a new power report being sent (% of previous report)
- Periodic Power & Energy Reports: Time period between consecutive power and energy reports being sent (in seconds)
- Energy Reports: The energy level change that will result in a new energy report being sent (% of previous report)
Fan Parameters
- SmartThings Hub
- VeraEdge
- VeraLite
- VeraPlus
- VeraSecure
- Wink and Wink 2 (no advanced settings)
These switches should also be recognized by any open systems that support multi-channel device types. If your hub is not listed above, please
get in touch with us before buying the switch to avoid the hassle of returns.
