The LZW31 Inovelli Dimmer Switch (Black Series) is a Z-Wave enabled smart switch that works with many different hubs and gateways and allows remote control from anywhere in the world.
Model #: LZW31 (Black Series)
Project Code Name: Knight Flank
Years Produced: November 2019 - Present
- Technology: Z-Wave Plus, S2 Encryption, SmartStart
- Z-Wave Chip: 500 Series
- 3-Way, 4-Way (Multi-Switch) Compatibility: Works with a dumb (existing) on/off switch (no dimming), auxiliary switch (GE or HomeSeer), or another Inovelli smart switch (via Z-Wave Association)
- Disable Internal Relay: Tap 8x on the config button to disable the internal relay
- Change Parameters Locally: Change parameters directly from the switch without the need for a Hub
- Accessories Included: White Faceplates/Paddles and a Neutral Wire Jumper (Almond not included)
- Neutral Wire Required: No (but recommended)
- Driver Type: MOSFET
- Leading/Trailing Edge: Leading Edge
- Max Wattage for Lights: See below -- maximum will vary based on bulb type and whether the heat sink tabs are removed or not
- Heat Sink Tabs Not Removed: 400W Incandescent, 300W LED, 150W CFL
- One (1) Side Heat Sink Tabs Removed: 300W Incandescent, 200W LED, 150W CFL
- Two (2) Sides Heat Sink Tabs Removed: 200W Incandescent, 150W LED, 100W CFL
- Min Wattage: If neutral wire is used, there is no minimum wattage required. However, if no neutral is installed, there needs to be at least 25W for the switch to work
- Use with Fan: No
- UL Certified: E508406
- FCC Certified: 2AB2QLZW31
- IC Certified: 10256A-LZW31
- Z-Wave Plus Certified: ZC10-19096763
Note about UL and IC:
- UL site requires a purchase to view the certification. Please see the PDF at the bottom of the article for UL records.
- IC site does not have a direct URL for devices -- it will take you to a search bar. Type the IC # in the, "Certification Number" section. Please see the PDF at the bottom of the article for a screenshot of the IC website.
- Dimming Speed: How fast or slow the light turns on (or dims) when you hold the switch (ie: dimming from 10-20%, 80-60%, etc)
- Dimming Speed (Z-Wave): How fast or slow the light turns on (or dims) when you adjust the switch remotely (ie: dimming from 10-20%, 80-60%, etc)
- Ramp Rate: How fast or slow the light turns on when you press the switch 1x to bring from On to Off or Off to On
- Ramp Rate (Z-Wave): How fast or slow the light turns on when you bring your switch from On to Off or Off to On remotely
- Minimum Dim Level: Minimum level the light switch will dim to
- Maximum Dim Level: Maximum level the switch will dim to
- Default Level (Local): Default dim level for the switch when pressed locally (at the switch)
- Default Level (Z-Wave): Default dim level for the switch when powered on via a Z-Wave command
- LED Indicator Color: This will set the default color of the LED Bar
- LED Indicator Intensity: This will set the intensity of the LED Bar (ie: how bright it is)
- LED Indicator Intensity (When Off): This is the intensity of the LED bar when the switch is off
- LED Indicator Timeout: Changes the amount of time the RGB Bar shows the dim level if the LED Bar has been disabled
- AC Power Type: Select whether you are wiring your switch with or without a neutral wireDi
- Switch Type: Select what type of installation you have (single-pole, 3-Way w/dumb switch, 3-Way w/aux switch)
- 2GIG (no advanced settings)
- ADT Pulse (no advanced settings)
- Alarm.com (no advanced settings)
- Almond (Securify) (no advanced settings)
- EZLO Atom
- InControl
- Indigo
- ISY (Only ISY994iZW +/IR-PRO -- DOES not work with ISY-994i)
- openHAB
- Open Z-Wave
- Piper (no advanced settings)
- Ring (no advanced settings)
- SmartThings Hub
- Staples Connect DLink (no advanced settings)
- Vivint Skycontrol (no advanced settings)
- Wink and Wink 2 (no advanced settings)
These switches should also be recognized by any open systems that support on/off (binary switch) device types. If your hub is not listed above, please
get in touch with us before buying the switch to avoid the hassle of returns.
