The LZW60 Inovelli 4-1 Sensor (Motion, Light, Humidity, Temperature) is a Z-Wave enabled smart sensor that works with many different hubs and gateways and allows remote monitoring from anywhere in the world.
Model #: LZW60
Project Code Name: Grand Slam
Generation: First
Years Produced: December 2019 - Present
- Technology: Z-Wave Plus, S2 Encryption, SmartStart
- Z-Wave Chip: 500 Series
- Sensors: Motion, Light/Lux, Humidity, Temperature
- Accessories Included: CR123A Battery, sensor stand, 3M adhesive, silicon pad, mounting screws, and battery compartment screw
- Power: Battery Powered (Micro-USB enabled, but not included)
- Battery Type: CR123A
- FCC Certified: 2AB2Q7ASSAABCH
- IC Certified: 10256A-7ASSAABCH0 *
- Z-Wave Plus Certified: ZC10-20016857
Note about IC:
- IC site does not have a direct URL for devices -- it will take you to a search bar. Type the IC # in the, "Certification Number" section. Please see the PDF at the bottom of the article for a screenshot of the IC website.
Low Battery Power Level Alarm: Value at which the sensor reports low battery
PIR Sensitivity: Change the sensitivity of the PIR (Motion) sensor
PIR Trigger Time (Time Between PIR Readings): The amount of seconds between motion detection (ie: the interval)
Basic Set Command Send After PIR Trigger: Choose whether Basic Set Command should be sent after PIR is triggered
PIR Trigger Correspondence Action: Ability to reverse the Basic Set behavior for devices associated in Group 2
Change Parameters 101-104 to Default Settings: If changes are made to parameters 101-104, you can set parameter 100 to 1 and reset 101-104 back to default
Temperature Reporting Interval: The interval between when temperature is reported to the gateway in seconds
Humidity Reporting Interval: The interval between when humidity is reported to the gateway in seconds
Luminance Reporting Interval: The interval between when luminance is reported to the gateway in seconds
Battery Reporting Interval: The interval between when battery is reported to the gateway
Change Parameters 111-114 to Default Settings: If changes are made to parameters 111-114, you can set parameter 110 to 1 and reset 111-114 back to default
Temperature Threshold: Set the threshold of the temperature for your sensor
Humidity Threshold: Set the threshold of the humidity for your sensor
Luminance Threshold: Set the threshold of the luminance for your sensor
Battery Threshold: Set the threshold of the battery for your sensor
- openHAB
- Open Z-Wave
- SmartThings Hub
- VeraEdge
- VeraLite
- VeraPlus
- VeraSecure
If your hub is not listed above, please
get in touch with us before buying the switch to avoid the hassle of returns.
