The LZW42 Inovelli RGBW (Multicolor) Smart Bulb is a Z-Wave enabled light bulb that works with many different hubs and gateways and allows remote control from anywhere in the world.
Make: Inovelli (Previously: Ilumin)
Model #: LZW42
Generation: Second
Years Produced: November 2019 - Present
Status: In Market
- Technology: Z-Wave Plus
- Z-Wave Chip: 500 Series
- Bulb Type: LED
- Bulb Shape: A19
- Bulb Base: E26
- Lumens: 806
- Wattage: 9.5W (60W Equivalent)
- Color Range: Full RGB (Red, Green, Blue) Color
- Temperature Range: 2700k to 6500k (Warm to Cold White)
- UL Listed: E345327
- FCC Certified: 2AB2Q6VY-A806ST-Q1G
- IC Certified: 10256A-YA806STQ1G
- Z-Wave Plus Certified: ZC10-19086720
Note about UL and IC:
- UL site requires a purchase to view the certification. Please see the PDF at the bottom of the article for UL records.
- IC site does not have a direct URL for devices -- it will take you to a search bar. Type the IC # in the, "Certification Number" section. Please see the PDF at the bottom of the article for a screenshot of the IC website.
Depending on the version, this bulb supports many advanced settings as shown below. Please reach out for the latest firmware file if you'd like to upgrade your firmware* (
NOTE: this requires a special tool that needs to be purchased separately unless your Hub supports Over-the-Air upgrades).
- State After Power Restored: Bulb will remember the last on/off, dim level and color prior to losing power
Current Firmware Version: 2.31
- openHAB
- Open Z-Wave
- SmartThings
If your hub is not listed above, please get in touch with us before buying the bulb to avoid the hassle of returns.
Smart speakers are NOT Z-Wave hubs so they won't work directly with any Z-Wave devices. But you can use a compatible Z-Wave hub with smart speaker integration to control your dimmer with voice control. These include the Fibaro hubs, Hubitat, SmartThings, and Wink.
