Device Parameters | RGBTW Smart LED Strip & Controller Kit | LZW45
Advanced Parameter Information
21
Quick Strip Effect
4
0- 2147483647
See Table 21.1 Below
(1) Sending Basic, Binary Switch, Multilevel, and Color SET will automatically disable the strip effect .
(2) Toggling OFF -> ON will cancel effect mode set on LED Strip and change the LED Strip back to the Previous color.
0
22
Custom Effect Para1
4
0- 2139062143
See table 22.1 below for details.
0
23
Custom Effect Para2
4
0- 1667457891
See table 23.1 below for details.
0
24
Custom Effect Para3
4
0- 1010580540
See table 24.1 below for details.
0
30
Custom Effect Para4
4
0- 197375
See table 30.1 below for details.
0
31
Multiple Effect Para
2
0-25444
Byte 1 – Level
Byte 0 – Effect
1-99
1-100
See table 31.1 below for details.
0
51
Button Delay
1
0~1
It determines whether or not the UP/DOWN key 1x press is delayed.
0 = no delay
1 = delay
1
Parameter 21
Table 21.1
Byte 4 –
Effect / Color Type
Byte 3 –
Duration
Byte 2 –
Level / Level Scale
Byte 1 –
Color
Bits 1~6:
0 – OFF
1 – Solid
2 – Chase(Only can display Hue wheel color)
3 – Fast Blink
4 – Slow Blink
5 – Fast Fade(Pulse)
6 – Slow Fade
Bits 7: Color Type
0 - Show Hue wheel color
1 – Show Color Temp
Value 1~60:
Use in seconds calculated
Value 61~120:
Use in minutes calculated by(value-60)
Example a value of 65 would be 65-60 = 5 minutes
Value 120-254:
Use in hours calculated by(value-120)
Example a value of 132 would be 132-120 would be 12 hours.
255 Indefinitely
Bits 1~7: Level value
Bits 8: Level Scale
When level scale = 0 (default), Level values 1~10 are available (like the switch and dimmer). The true level is x*10. So if the Level value setting is 3 then the level is 30%.
When level scale = 1 the level can be 1~99 to allow a greater level of resolution.
Color values(x)
When Color Type = 0, device need to display color, use the hue color wheel to calculate the color value.
Color value = x/255*360.
When Color Type = 1, device need to display color temp.
Color temp value = x/255*(6500-2700)+2700.
Parameter 22
Table 22.1
Byte 4 – Color / Effect for action #4
Byte 3 – Color / Effect for action #3
Byte 2 – Color / Effect for action #2
Byte 1 – Color / Effect for action #1
Bit 3-7
Bit 0-2
0 – Off
1– 2700K
2– 4500K
3– 6500K
4- Red
5- Orange
6 - Yellow
7–Yellow Green
8 - Green
9–Spring Green
10 – Cyan
11- Azure
12-Blue
13- Violet
14-Magenta
15-Random
0 – Fade
1 – Fade Blend
2 – Flash
3 – Chase
4 – Chase Blend
Bit 3-7
Bit 0-2
0 – Off
1– 2700K
2– 4500K
3– 6500K
4- Red
5- Orange
6 - Yellow
7–Yellow Green
8 - Green
9–Spring Green
10 – Cyan
11- Azure
12-Blue
13- Violet
14-Magenta
15-Random
0 – Fade
1 – Fade Blend
2 – Flash
3 – Chase
4 – Chase Blend
Bit 3-7
Bit 0-2
0 – Off
1– 2700K
2– 4500K
3– 6500K
4- Red
5- Orange
6 - Yellow
7–Yellow Green
8 - Green
9–Spring Green
10 – Cyan
11- Azure
12-Blue
13- Violet
14-Magenta
15-Random
0 – Fade
1 – Fade Blend
2 – Flash
3 – Chase
4 – Chase Blend
Bit 3-7
Bit 0-2
0 – Off
1– 2700K
2– 4500K
3– 6500K
4- Red
5- Orange
6 - Yellow
7–Yellow Green
8 - Green
9–Spring Green
10 – Cyan
11- Azure
12-Blue
13- Violet
14-Magenta
15-Random
0 – Fade
1 – Fade Blend
2 – Flash
3 – Chase
4 – Chase Blend
Parameter 23
Table 23.1
Byte 4 – Level for action #4
Byte 3 – Level for action #3
Byte 2 – Level for action #2
Byte 1 – Level for action #1
0-99
Level of the strip during the strip effect.
0-99
0-99
0-99
0-99
0-99
0-99
0-99
Parameter 24
Table 24.1
Byte 4 – Duration for action #4
Byte 3 – Duration for action #3
Byte 2 – Duration for action #2
Byte 1 – Duration for action #1
1-60
Duration of strip effect.
1-60
1-60
1-60
Parameter 30
Table 30.1
Byte 4 –
Reserved
Byte 3 – Duration Scale in Param 24
Byte 2 – Effect Finished Behavior
Byte 1 – Number of Iterations
0 – 100 ms
1 – Seconds
2 – Minutes
3 – Hours
0 – Off
1 – Previous Color
2 – Last Color in Program
0 - Off
1 – 254 iterations
255 - Forever
