Compatible Bulbs & Fans - Fan/Light Switch
Note: This is a live document that is constantly changing
There are many different bulbs and fans that are compatible with our fan and light switch. The important thing to remember is that our dimming portion of the fan/light switch uses TRIAC (different from our Dimmer switches that use MOSFET), leading edge technology, so the bulb(s) you choose should be the same. In addition, the fan portion is only compatible with AC rated fans. Below are bulbs and fans that are compatible and not compatible with our switch.
This article relates to our Fan/Light Switch:
Compatible Bulbs
Below are the bulbs that have been tested compatible with our Gen 2 Dimmers. Some will require a min/max setting from the switch.
A19/E26 Bulbs
LED Bulbs
CFL Bulbs
Candelabra Bulbs
LED Bulbs
- Feit - 40W Equivalent, 3000k Soft White - Candelabra - Model #BPA15C/CL/DM/LED (Amazon, Amazon.ca)
Incompatible Bulbs
Below are the bulbs that have been tested or reported to be incompatible with our Gen 2 Dimmers. Please do not use these.
A19/E26 Bulbs
LED Bulbs
Compatible Fans
Below are the fans that have been tested compatible with our Fan/Light Switch. Remember, the fans need to be AC Rated.
Compatible Bulbs - Gen 2 Dimmers
Note: This is a live document that is constantly changing. If you'd like to make a contribution, please post in our community or reach out to us. Summary (TLDR) There are many different bulbs that are compatible with our dimmer switches. The ...
Wiring Diagrams for Ceiling Fan + Light Switch
Overview These wiring diagrams should only be used for our fan & light switch and should not be used for anything other than a ceiling fan (ie: no exhaust fans). Pre-Requisites & Comments Neutral Wire is Required at both the switch and canopy ...
Spec Sheet | Fan + Light - Red Series (Gen 2) | LZW36
NOTE: This is a work in progress and features/specs are subject to change. Please see our community thread to stay up to date: https://community.inovelli.com/t/fan-light-switch-project-hurricane-pre-orders-now-open/23 The LZW36 Inovelli Fan + Light ...
Setup Instructions • Blue Series Fan Switch • SmartThings
ARTICLE UNDER CONSTRUCTION - WE ARE MOVING OUR KB FROM THE COMMUNITY BACK TO THE SUPPORT SITE. THANKS FOR YOUR PATIENCE. REMINDER: This switch is only to be used to control lights (except ballasts or any lights connected to a transformer). Do not use ...
Device Handler Installation | LZW36 | Fan & Light Switch
This article will walk you through the features of the custom device handler and how to install it for optimal usage and advanced functionality on your Inovelli Fan & Light Switch (LZW36) . We promise it's not hard and should take you 5-10 minutes ...
