Device Handler Installation | LZW41 | CCT (Tunable White) A19 Bulb | SmartThings
NOTE: As of January 2020, you will no longer need to install the device handler for this product to work as it's WWST (Works With SmartThings) Certified. However, if you'd like some additional functionality, please feel free to install the device handler below.
This article will walk you through the features of the custom device handler and how to install it for optimal usage and advanced functionality on your Ilumin (Powered by Inovelli) Tunable White A19 Bulb (LZW41) . We promise it's not hard and should take you 5-10 minutes tops.
  1. SmartThings IDE Tab Open:   https://account.smartthings.com/  (sign in with the same info as you do with the app)
  2. Device Handler Code Tab Open: LZW41 Raw Code
We recommend installing the device handler prior to installing your bulb, but it really doesn't matter. There will just be a few additional steps you'll need to take if you install the handler after you install and pair your bulb.
Installing the Code
  1. Open up IDE  and go to "My Device Handlers"
  3. Next click on, "From Code"
  4. Now switch tabs and go to the LZW41 Raw Code link in GitHub
  9. Finally, click on, "Publish" and "For Me" and you're all set
NOTE: If you haven't paired your bulb yet, feel free to install/pair it and the bulb should automatically detect the device handler (the bulb will show up as: Inovelli Bulb Multi-White). If you already paired your bulb and/or it showed up as a, "Z-Wave Bulb" (or something like that), you'll have to associate the new handler to the bulb. To do this, follow the directions below.
You'll only need to do this step if you already paired your bulb or the bulb is showing up as a, "Z-Wave Bulb" (or anything other than, "Inovelli Bulb Multi-White"). To do this do the following:
  1. In IDE, click on, "My Devices"
  2. Locate your Ilumin (Powered by Inovelli) Bulb and click on it
  3. Scroll to the bottom and click, "Edit"
  4. Scroll down about halfway where it says, "Type" and click on it (a dropdown will appear)
  5. In the dropdown, scroll down until you find, "Inovelli Bulb Multi-White" and select it
  6. Click, "Update" and you should be all set
Checking For Success
  1. Open up your SmartThings app
  2. Locate your Ilumin Bulb and click on it
  3. Click on the three dots at the top right and select, "Settings"
  4. You should see a few more options available to you now
    • Inclusion & Exclusion | CCT (Tunable White) A19 Bulb
      Summary (TLDR) Please see below for basic inclusion/exclusion information around the LZW41 - CCT (Tunable White) A19 Bulb. For more hub/gateway specialized instructions, please click on the URL's in the third section below to be taken to the specific ...
    • Device Handler Installation | LZW42 | RGBW (Multi-Color) A19 Bulb | SmartThings
      This article will walk you through the features of the custom device handler and how to install it for optimal usage and advanced functionality on your Ilumin (Powered by Inovelli) RGBW A19 Bulb (LZW42). We promise it's not hard and should take you ...
    • Installation & Setup | LZW41 | CCT (Tunable White) A19 Bulb | SmartThings
      This article will walk you through how to setup your Ilumin (Inovelli) tunable white smart bulb with your Samsung SmartThings Hub. For more advanced features such as Device Handler Installation, please see the recommended articles below. Spec Sheet ...
    • Spec Sheet | CCT (Tunable White) - A19 Bulb | LZW41
      The LZW41 Inovelli CCT (Tunable White) Smart Bulb is a Z-Wave enabled light bulb that works with many different hubs and gateways and allows remote control from anywhere in the world. Overview Make: Ilumin (Powered by Inovelli) Model #: LZW41 Project ...
    • How To: Install a Device Handler (SmartThings)
      Overview Sometimes a third party Device Handler (DTH) is required to "unlock" special features on a device when paired to SmartThings. When originally paired, a device will be auto-assigned to a SmartThings specific device type and normally these ...
