Click on "Devices" and then "+ Add Device" to start the process of adding your device to the network.
Scroll down and choose "Generic Z-Wave device".
Click through the prompts until you get to the screen that says "Follow the inclusion process as described in the users manual".
At this point you can press the button on the back of the sensor 1 time. Vera should eventually show a spinning wheel and proceed onto the next step.
Choose a name for your device and a room if you desire. Click "finish" to proceed.
Finally, the device will show up in your devices list and the inclusion is complete!
If for some reason the switch is not including, first make sure you are within range. Next, try an exclusion of the device before trying an inclusion. For an exclusion, the steps are the same as above except that during inclusion, Vera will suggest to try an exclusion if it detects a problem (after you hit "Retry" when the inclusion timer times out). After the removal process begins, press the button on the back of the sensor 1 time. After the exclusion is complete, you can proceed with the inclusion as stated in these instructions.
This article will walk you through how to setup your Inovelli 4-1 Multi-Sensor from a physical installation to pairing it to your Samsung SmartThings Hub. For more advanced features such as Parameter Configuration, and Device Handler Installation ...
This article will walk you through how to setup your Inovelli 4-1 Multi-Sensor from a physical installation to pairing it to your Hubitat Elevation Hub. For more advanced features such as Parameter Configuration, and Device Handler Installation ...
This article will walk you through how to setup your Ilumin CCT (Tunable White) A19 bulb using the Hubitat Elevation hub. Spec Sheet Prerequisites Device Driver Installed: Please have the LZW42 Device Driver installed prior to pairing/including this ...
