This article will walk you through how to setup your Inovelli 4-1 Multi-Sensor from a physical installation to pairing it to your Samsung SmartThings Hub. For more advanced features such as Parameter Configuration, and Device Handler Installation please see the articles below.
There are a couple of different ways to install your sensor: Temporary or Permanent
Permanent: Please use the included screws to mount to a wall (use the included drywall anchors if mounting to drywall). Note that the Base (E) should be unscrewed first to make it easier to drill the screws into the wall and ensure that the sensor holes (F) are pointed down at the floor.
Temporary: Please use the included adhesive tape (to install, please clean the surface of the area you're mounting to, put the adhesive on the Base (E) and then mount on the wall, holding down for 30 seconds) and ensure that the sensor holes (F) are pointed down at the floor.
Adding to SmartThings
As of February 28, 2020, SmartThings is transitioning its users to the new SmartThings App and the Classic App will be phased out. Therefore our instructions will only be available for the new app.
Installing a Device Handler (Recommended)
For optimal performance and to access all the advanced features, you'll want to install our custom device handler. We recommend you do this first, but you can definitely do it after you pair your sensor. We wanted to keep this article short, so we've created a separate page for installing the handler. It can be found here: LZW60 Device Handler Instructions
Pairing (Inclusion) Steps
NOTE: The below directions assume you have installed the device handler prior to pairing.
Open your SmartThings App
Press the (+) button at the top right of the screen
Click on, "Device"
Click on, "Scan" at the top right
On the back of your sensor, press the Sensor Button (B) one (1) time
The LED light (on the front) will flash RED indicating the sensor is in inclusion/pairing mode
If successful, the LED light will stop flashing and turn solid RED for 1-2 seconds
If unsuccessful, the LED light will keep flashing and eventually timeout after about 25-30 seconds
Once successful, you'll see, "Inovelli 4-1 Sensor" show up on the screen -- feel free to rename it if you'd like
Excluding (Factory Resetting) the Sensor
Sometimes the sensor will not pair and needs to be factory reset. There are a couple of ways to do this. The first is via the sensor itself, while the second is via the SmartThings App.
Resetting via the Sensor
Hold down the Sensor Button (B) for 5 Seconds
Resetting via the SmartThings App
From the home screen, click on the three lines at the top left of your screen to open the menu
Click on the, "Devices" icon
In the search bar, search, "Hub" and select your Hub
Click on the three dots at the top right of the screen and select, "Z-Wave Utilities"
Then press, "Z-Wave Exclusion" and the process will start
On your Inovelli sensor, press the Sensor Button (B) one (1) time
In addition, the SmartThings app should say that your sensor was excluded successfully
For advanced functionality, you'll want to install our device handler where you can modify parameters easily. As always, if you need help, please reach out, we're happy to assist.
NOTE: If you are pairing this device to work directly with an Ilumin RGBW or CCT Smart Bulb via Z-Wave Association, you will need to pair this in S0 mode. Abbreviated Instructions for Pairing In the SmartThings App, click on the (+) button, then ...
This article will walk you through the features of the custom device handler and how to install it for optimal usage and advanced functionality on your Inovelli 4-1 Multi-Sensor (LZW60). We promise it's not hard and should take you 5-10 minutes tops. ...
This article will walk you through how to setup your Inovelli On/Off Switch (Black Series) from an in-wall installation to pairing it to your Samsung SmartThings Hub. For more advanced features such as Parameter Configuration, Device Handler ...
This article will walk you through how to setup your Inovelli On/Off Switch (Red Series) from an in-wall installation to pairing it to your Samsung SmartThings Hub. For more advanced features such as Parameter Configuration, Device Handler ...
