This article will walk you through how to setup your Inovelli 4-1 Multi-Sensor from a physical installation to pairing it to your Samsung SmartThings Hub. For more advanced features such as Parameter Configuration, and Device Handler Installation ...
This article will walk you through how to setup your Inovelli 4-1 Multi-Sensor from a physical installation to pairing it to your Hubitat Elevation Hub. For more advanced features such as Parameter Configuration, and Device Handler Installation ...
This article will walk you through how to setup your Ilumin CCT (Tunable White) A19 bulb using the Hubitat Elevation hub. Spec Sheet Prerequisites Device Driver Installed: Please have the LZW42 Device Driver installed prior to pairing/including this ...
