Installation & Setup | LZW41 | CCT (Tunable White) A19 Bulb | Wink
Coming Soon!
    • Inclusion & Exclusion | CCT (Tunable White) A19 Bulb
      Summary (TLDR) Please see below for basic inclusion/exclusion information around the LZW41 - CCT (Tunable White) A19 Bulb. For more hub/gateway specialized instructions, please click on the URL's in the third section below to be taken to the specific ...
    • Device Handler Installation | LZW41 | CCT (Tunable White) A19 Bulb | SmartThings
      NOTE: As of January 2020, you will no longer need to install the device handler for this product to work as it's WWST (Works With SmartThings) Certified. However, if you'd like some additional functionality, please feel free to install the device ...
    • Spec Sheet | CCT (Tunable White) - A19 Bulb | LZW41
      The LZW41 Inovelli CCT (Tunable White) Smart Bulb is a Z-Wave enabled light bulb that works with many different hubs and gateways and allows remote control from anywhere in the world. Overview Make: Ilumin (Powered by Inovelli) Model #: LZW41 Project ...
    • Installation & Setup | LZW41 | CCT (Tunable White) A19 Bulb | Hubitat
      This article will walk you through how to setup your Ilumin CCT (Tunable White) A19 bulb using the Hubitat Elevation hub. Spec Sheet  Prerequisites Device Driver Installed:  Please have the LZW41 Device Driver installed prior to pairing/including ...
    • Installation & Setup | LZW31 | Dimmer - Black Series (Gen 2) | Wink
      This article will walk you through how to setup your Inovelli Dimmer Switch (Black Series) from an in-wall installation to pairing it to your Wink Hub. For more advanced features such as Parameter Configuration, please see the recommended articles ...
