Installation & Setup | LZW41 | CCT (Tunable White) A19 Bulb | SmartThings
This article will walk you through how to setup your Ilumin (Inovelli) tunable white smart bulb with your Samsung SmartThings Hub. For more advanced features such as Device Handler Installation, please see the recommended articles below.
Adding to SmartThings
As of February 23, 2020, SmartThings is transitioning its users to the new SmartThings App and the Classic App will be phased out. Therefore our instructions will only be available for the new app.
For optimal performance and to access all the advanced features, you'll want to install our custom device handler. We recommend you do this first, but you can definitely do it after you pair your bulb. We wanted to keep this article short, so we've created a separate page for installing the handler. It can be found here: LZW41 Device Handler Instructions
Pairing (Inclusion) Steps
NOTE: The below directions assume you have not installed the device handler prior to pairing.
  1. Disconnect power from the bulb
  2. Open your SmartThings App
  3. Press the (+) button at the top right of the screen
  4. Click on, "Device"
  5. Click, "Scan" at the top right of the screen
  6. Restore power to the bulb - it should blink twice to confirm the bulb is in inclusion/pairing mode
  7. If successful, the bulb should blink once more
  8. In addition, your app will show your bulb
  9. Click back to the main devices tab and look for your bulb!
NOTE:  This is for the RGBW bulb, but the same inclusion method applies for the Tunable White (CCT) bulb.
Excluding (Factory Resetting) the Bulb
Sometimes the bulb will not pair and needs to be factory reset. There are a couple of ways to do this. The first is via the bulb itself, while the second is via the SmartThings App.
Resetting via the Bulb
  1. Power on/off the bulb 6x (between 0.5 - 2 seconds)
Resetting via the SmartThings App
  2. From the home screen, click on the three lines at the top left of your screen to open the menu
  3. Click on the, "Devices" icon
  4. In the search bar, search, "Hub" and select your Hub
  5. Click on the three dots at the top right of the screen and select, "Z-Wave Utilities"
  6. Then press, "Z-Wave Exclusion" and the process will start
  7. Restore power to the bulb - it should blink twice to confirm the bulb is in exclusion mode
  8. If successful, the bulb should blink once more
  9. In addition, the SmartThings app should say that your switch was excluded successfully
NOTE:   This is for the RGBW bulb, but the same exclusion method applies for the Tunable White (CCT) bulb.
