Go back to the Hubitat web interface and paste the code into the white box
Click, “Save” – wait for the red, “Modified” word to disappear (this indicates the code was saved properly)
Adding to Hubitat
NOTE: Please install the Device Driver prior to pairing/including to Hubitat.
Pairing (Inclusion) Steps
We will use the Hubitat App for this. Again, please make sure you've installed the LZW41 Device Driver before starting the pairing process.
Turn power off to your bulb (either by unscrewing it, turning off the lamp, or flipping the switch off)
Open your Hubitat App
Click on, "Devices"
Next click, "Discover Devices" at the top right
Select, "Z-Wave"
Select, "Start Z-Wave Inclusion"
Turn power onto your bulb -- it should blink twice
If successful, your bulb will blink a third time to indicate it has included successfully
In addition, if you scroll down under where it says, "Start Z-Wave Exclusion", if successful, the app will show, "Found Devices" and it should list out the Ilumin/Inovelli bulb
Name the device and click, "Save"
To find your switch, go to the menu and click on, "Devices" -- you should see it listed there.
NOTE: The below video shows our RGBW bulb. The pairing process is the same for the CCT bulb (the only difference is the Device Driver).
Excluding (Factory Resetting) the Bulb
Sometimes the bulb will not pair and needs to be factory reset. There are a couple of ways to do this. The first is via the bulb itself, while the second is via the Hubitat App.
Resetting via the Bulb
Power on and off the bulb 6x within 2 seconds
Resetting via the Hubitat App
From the home screen, click on the, "Settings" tab
Next click on, "Z-Wave Details"
Finally click on the Z-Wave Exclusion button
Turn on power to your bulb
If the exclusion was successful, your Ilumin/Inovelli bulb should then turn dim to confirm
In addition, the Hubitat app should say that your switch was excluded successfully
NOTE: The below video shows our RGBW bulb. The exclusion/removal process is the same for the CCT bulb.
Summary (TLDR) Please see below for basic inclusion/exclusion information around the LZW41 - CCT (Tunable White) A19 Bulb. For more hub/gateway specialized instructions, please click on the URL's in the third section below to be taken to the specific ...
This article will walk you through how to setup your Ilumin CCT (Tunable White) A19 bulb using the Hubitat Elevation hub. Spec Sheet Prerequisites Device Driver Installed: Please have the LZW42 Device Driver installed prior to pairing/including this ...
This article will walk you through how to setup your Ilumin (Inovelli) tunable white smart bulb with your Samsung SmartThings Hub. For more advanced features such as Device Handler Installation, please see the recommended articles below. Spec Sheet ...
The LZW41 Inovelli CCT (Tunable White) Smart Bulb is a Z-Wave enabled light bulb that works with many different hubs and gateways and allows remote control from anywhere in the world. Overview Make: Ilumin (Powered by Inovelli) Model #: LZW41 Project ...
