Installation & Setup | LZW31 | Dimmer - Black Series (Gen 2) | SmartThings
NOTE: If you are pairing this device to work directly with an Ilumin RGBW or CCT Smart Bulb via Z-Wave Association, you will need to pair this in S0 mode.
Abbreviated Instructions for Pairing
In the SmartThings App, click on the (+) button, then "Device", then Scan QR Code (located at the bottom left of your switch). Next, click, "Start", select your hub and room where you'd like your switch to show up and click, "Next". Finally, press the config button 3x until it pulses blue. Once complete, the LED bar should flash GREEN if successful and you'll be taken to a screen where you can rename the switch. NOTE: Sometimes it will make you scan the QR Code again (please do so) or it will say something like, "Not all Security Features Implemented" -- you can either ignore this (switch will be paired with S0 Encryption) or try pairing closer to the hub (to get S2 Encryption). Our recommendation would be to leave it at S0 for now until ST has S2 fully implemented.
This article will walk you through how to setup your Inovelli Dimmer Switch (Black Series) from an in-wall installation to pairing it to your Samsung SmartThings Hub. For more advanced features such as Parameter Configuration, Device Handler Installation, please see the recommended articles below.
Switch Overview: Understand the basics of the switch, such as the Config Button (A), LED Bar (B), and Line/Load/Neutral/Traveler Terminals as shown in the Spec Sheet - Getting to Know Your Switch section
If you are unsure how to determine the various wires, please consult an electrician or post in our community in the dedicated Wiring Discussion section. We are unable to give electrical advice due to liability concerns.
Line: This is where your power (120V AC) comes from and is considered your, "Hot" wire. Usually a black wire.
Load: This is what your switch controls (ie: your light). Usually a black wire.
Neutral: Completes your circuit (and is what powers your Z-Wave chip). Usually a white wire.
Traveler (Optional): This is used in a 3-Way or Multi-Switch setup. Usually a red wire.
Single Pole: One switch that controls your Load
3-Way: Two switches that control your Load
4-Way: Three switches that control your Load
Do I have a neutral wire (if the answer is no, you'll need to purchase our LZW31 or LZW31-SN Dimmer Switches)
How many switches control my Load?
Do I want to leave my dumb/existing switch in or replace it with an Auxiliary Switch?
Once these questions have been answered, look at the Wiring Guide and prepare for installation.
After reviewing the Wiring Guide and determining your setup, it's time to install your switch. Again, if you don't know what you're doing, please don't try this on your own and consult an electrician. We cannot give out electrical advice due to liability reasons.
Carefully pull your existing switch out from the wall to determine where the Line and Load wires are located and keep note
NOTE: In a 3-Way, 4-Way or Multi-Switch setting, the Inovelli switch needs to be installed where the Line wire is located
Go to the circuit breaker and turn off power to the switch
Make sure the wires are tightly secured before finalizing the installation as loose wires will cause problems
Carefully finish installing the switch into the wall (NOTE: Do not put the faceplate on yet as you'll want to scan the QR Code)
Restore power and test your switch for manual operation -- you should see a boot sequence like this when first powered on (Red, Green, Blue):
Adding to SmartThings
As of February 23, 2020, SmartThings is transitioning its users to the new SmartThings App and the Classic App will be phased out. Therefore our instructions will only be available for the new app.
This step is optional, but it will allow you to understand if your switch is within range of your SmartThings Z-Wave antenna.
Hold down the Configuration Button (A) for five (5) seconds until the LED Bar (B) lights up GREEN
Once it lights up GREEN, release the Configuration Button (A)
If the LED Bar (B) stays GREEN, the device is within range
If the LED Bar (B) turns RED, the device is not within range and needs to be moved
Installing a Device Handler (Recommended)
For optimal performance and to access all the advanced features, you'll want to install our custom device handler. We recommend you do this first, but you can definitely do it after you pair your switch. We wanted to keep this article short, so we've created a separate page for installing the handler. It can be found here: LZW31 Device Handler Instructions
NOTE: The below directions assume you have installed the device handler prior to pairing and do not want to associate to an Ilumin Z-Wave bulb. If you do want to associate the switch to an Ilumin bulb, please click here: Pairing in S0 Mode.
Open your SmartThings App
Press the (+) button at the top right of the screen
Click on, "Device"
Click, "Scan QR Code" at the top right of the screen
Scan the QR Code at the bottom left of your switch (faceplate should be off)
SmartThings should start the inclusion process - click, "Next" and select your hub and room and then click, "Next" again
On your Inovelli switch, press the Config Button (A) 3x rapidly and the LED Bar (B) will pulse BLUE (if it doesn't, please tap the config button faster)
If successful, your Inovelli switch LED Bar (B) will turn GREEN (if unsuccessful, the LED Bar will turn RED)
In addition, your app will show a device called, "Inovelli LZW31 Dimmer" -- feel free to rename it
Click back to the main devices tab and look for your switch!
Pairing (Inclusion) Steps - S0 Encryption (Use for Z-Wave Associations)
NOTE: The below directions assume you have installed the device handler prior to pairing and want to associate to an Ilumin Z-Wave bulb. If you do not want to associate the switch to an Ilumin bulb, please click here: Pairing in S2 Mode.
Click on, "Device"
Click, "Scan Nearby" at the top right of the screen
Sometimes the switch will not pair and needs to be factory reset. There are a couple of ways to do this. The first is via the switch itself, while the second is via the SmartThings App.
Hold down the Config Button (A) for 20 Seconds or until it turns/blinks RED
Resetting via the SmartThings App
From the home screen, click on the three lines at the top left of your screen to open the menu
Click on the, "Devices" icon
In the search bar, search, "Hub" and select your Hub
Click on the three dots at the top right of the screen and select, "Z-Wave Utilities"
Then press, "Z-Wave Exclusion" and the process will start
On your Inovelli Switch, press the config button 3x rapidly (the LED bar should pulse blue)
If the exclusion was successful, your Inovelli switch LED bar should turn from pulsing blue to GREEN
In addition, the SmartThings app should say that your switch was excluded successfully
For advanced functionality, you'll want to install our device handler where you can modify parameters easily. As always, if you need help, please reach out, we're happy to assist.
This article will walk you through how to setup your Inovelli On/Off Switch (Black Series) from an in-wall installation to pairing it to your Samsung SmartThings Hub. For more advanced features such as Parameter Configuration, Device Handler ...
This article will walk you through how to setup your Inovelli Dimmer Switch (Black Series) from an in-wall installation to pairing it to your Wink Hub. For more advanced features such as Parameter Configuration, please see the recommended articles ...
NOTE: If you are pairing this device to work directly with an Ilumin RGBW or CCT Smart Bulb via Z-Wave Association, you will need to pair this in S0 mode. Abbreviated Instructions for Pairing In the SmartThings App, click on the (+) button, then ...
This article will walk you through how to setup your Inovelli On/Off Switch (Red Series) from an in-wall installation to pairing it to your Samsung SmartThings Hub. For more advanced features such as Parameter Configuration, Device Handler ...
