Wiring Diagrams for Ceiling Fan + Light Switch
These wiring diagrams should only be used for our fan & light switch and should not be used for anything other than a ceiling fan (ie: no exhaust fans).
- Neutral Wire is Required at both the switch and canopy
- Inovelli switch needs to be installed where the Line (120V) is located
- The switch is not meant to work in a 3-Way or multi-switch setting
- Max Horsepower (Fan): 1/6 HP
- Max Wattage (Lights): 200W Incandescent or 100W CFL/LED
- AC/DC Motor Compatibility: Only compatible with AC Motors
WARNING: Not all wire colors shown may be the same as what's in your box or at the fan. While we've tried our best to match the most common setups, local electrical codes may be different than what's depicted. If your wire colors do not match, please use a multi-meter to check for continuity, hire an electrician or
Wiring Discussion in our Community where someone can help. Again, we are unable to give specific wiring advice ourselves due to liability issues.
Multiple Fans w/One Switch: This is a common question and while this has been tested internally to work (as long as you stay under the Max Horsepower and Max Wattage) it was not tested by UL and it will void your warranty.
Wiring Diagrams
Please remember that this switch and canopy module can only be used for AC Rated Ceiling Fans. Do not use them on DC Rated fans or Exhaust fans.
Power Goes Into Switch Box
Use the following schematics for if your 120V Line goes into the switch box.
Switch Used for Fan and Lights
Use this schematic if you're currently use your light switch to turn on both your fan and light (no pull-strings).
Power Goes Into Fan Box
Scenario #1: Switch Used for Turning On Lights / Pull-String Used for Fan Control
Use this schematic if you're currently using your light switch to turn on the lights on your fan and the pull-string for controlling the fan.
Scenario #2: Switch Used for Turning On Fan / Pull-String Used for Turning On Lights
Use this schematic if you're currently using your light switch to turn on the fan and the pull-string for controlling the lights.
Scenario #3: Switch Used for Turning On Both Fan & Lights (No Pull-String Used)
Use this schematic if you're currently using your light switch to turn on both the fan and the lights simultaneously.
Installation & Setup | LZW36 | Fan + Light Red Series (Gen 2) | SmartThings
Wiring Diagrams for Dimmer Switches | Gen 1
Wiring Diagrams for Gen 1 Dimmer Switches These wiring diagrams should only be used for our Gen 1 dimmer switches, which are shown below -- do not use these for Gen 2! Pre-Requisites Neutral Wire is Required Inovelli switch needs to be installed ...
Wiring Diagrams for On/Off Switches | Gen 1
Wiring Diagrams for Gen 1 On/Off Switches These wiring diagrams should only be used for our Gen 1 on/off switches, which are shown below -- do not use these for Gen 2! Pre-Requisites Neutral Wire is Required Inovelli switch needs to be installed ...
Wiring Diagrams for Dimmer Switches | Gen 2
Wiring Diagrams for Gen 2 Dimmer Switches These wiring diagrams should only be used for our Gen 2 dimmer switches, which are shown below -- do not use these for Gen 1! Pre-Requisites Neutral Wire is NOT Required (But Recommended) Inovelli switch ...
Spec Sheet | Fan + Light - Red Series (Gen 2) | LZW36
NOTE: This is a work in progress and features/specs are subject to change. Please see our community thread to stay up to date: https://community.inovelli.com/t/fan-light-switch-project-hurricane-pre-orders-now-open/23 The LZW36 Inovelli Fan + Light ...
