Inclusion / Exclusion | Dimmer - Red Series (Gen 2)
Please see below for basic inclusion/exclusion information around the LZW31-SN - Red Series Dimmer Switch. For more hub/gateway specialized instructions, please click on the URL's in the third section below to be taken to the specific installation page.
This article pertains to the above product: LZW31-SN - Dimmer Red Series Switch (Gen 2)
Basic Exclusion / Inclusion Instructions
If you're familiar with how to put your hub/gateway into exclusion/inclusion mode and just need to know how to activate it at the switch, please follow these instructions.
Exclusion (Factory Reset)
After putting your hub/gateway into exclusion mode, please do the following:
  1. Tap the config button 3x (the LED bar should pulse BLUE)
  2. If successful, the LED bar should flash GREEN (if unsuccessful, the LED bar should flash RED)
Pro tip: If your LED bar is lit up, but never pulses, try tapping the button faster
Inclusion (Pairing)
After putting your hub/gateway into inclusion mode, please do the following:
HUB/Gateway Specific Instructions
Please click on the hyperlinks below for hub specific instructions:
  1. Home Assistant
  2. HomeSeer
  3. Hubitat
  4. SmartThings
  5. Wink
