This article will walk you through how to install the device driver for optimal usage and advanced functionality on your Inovelli LED Strip & Controller Kit (LZW45). We promise it's not hard and should take you 5-10 minutes tops. Prerequisites ...
This article will walk you through how to setup your Inovelli On/Off Switch (Red Series) from an in-wall installation to pairing it to your Hubitat Elevation Hub. For more advanced features such as Parameter Configuration, Device Handler ...
This article will walk you through how to setup your Inovelli On/Off Switch (Black Series) from an in-wall installation to pairing it to your Hubitat Elevation Hub. For more advanced features such as Parameter Configuration and Device Handler ...
