How To: Use the Configuration Button On Your Device
Coming Soon!
    • How To: Use the Configuration Button On Your Device (Gen 2 Dimmers)
      Prerequisites Inovelli Model #'s: LZW31-SN (Red Series) and LZW31 (Black Series)  Switch Configuration Settings: Parameter # # of Times to Press Config Button About Description Range Range Description Default Video 1 1 Dimming Speed How fast or slow ...
    • How To: Set Your Config Button as Your Favorites Button | SmartThings
      Overview Many times you just want a quick way to reach a certain dim level or you'd like to activate your favorite scene (ie: turn off all lights between the hours of 10pm and 6am). In this tutorial, we'll show you how to turn your configuration ...
    • FAQ's: Button Mapping for Scene Control
      Summary (TLDR) Below you'll find the various button mappings for our products. These mappings will help you setup your scenes (ie: 2x Tap, 3x Tap, etc) from within your hub. The following products have scene control built in: LZW30-SN - Red Series ...
    • Hubitat Device Drivers
      Device Driver Locations Please see the following locations for each Inovelli Device Driver. Then follow the instructions below! Master Location: https://github.com/InovelliUSA/Hubitat Switches LZW30 - On/Off (Black Series) - Gen 2 LZW30-SN - On/Off ...
    • Device Driver Installation | LZW45 | Lightstrip & Controller Kit
      This article will walk you through how to install the device driver for optimal usage and advanced functionality on your Inovelli LED Strip & Controller Kit (LZW45). We promise it's not hard and should take you 5-10 minutes tops. Prerequisites ...
