When you're changing hubs (ie: Wink/ST to Hubitat) you'll need to make sure your products are successfully reset (or excluded) from the previous hub. If you're having issues pairing your device to Hubitat, you may need to exclude (reset) the devices before including (pairing) them. The good news is you do not need to do this with the prior hub and you can do this all from Hubitat.
Below we'll give you directions to exclude/reset and include/pair all Inovelli devices so that they'll work with Hubitat.
Switches
The following section will provide you instructions on how to exclude/reset and include/pair Gen 1 and Gen 2 smart switches.
Gen 2 - On/Off & Dimmer Switches
Please use the directions below for the following products (from left to right: LZW30, LZW30-SN, LZW31, LZW31-SN):
Exclusion/Reset
Please follow the below instructions to exclude/reset your Gen 2 On/Off and/or Dimmer Switches (Red & Black Series):
- From the home screen, click on the, "Settings" tab
- Next click on, "Z-Wave Details"
- Finally click on the Z-Wave Exclusion button
- On your Inovelli Switch, press the config button 3x rapidly (the LED bar should pulse blue)
- If the exclusion was successful, your Inovelli switch LED bar should turn from pulsing blue to GREEN
- In addition, the Hubitat app should say that your switch was excluded successfully
Inclusion/Pairing
Before inclusion/pairing, please make sure you have the latest
Device Driver Installed (search for the correct model). Below are the instructions to include/pair your Gen 2 On/Off and/or Dimmer Switches (Red & Black Series):
- Open your Hubitat App
- Click on, "Devices"
- Next click, "Discover Devices" at the top right
- Select, "Z-Wave"
- Select, "Start Z-Wave Inclusion"
- On your Inovelli switch, press the Config Button (A) 3x rapidly and the LED Bar (B) will pulse BLUE
- If successful, your Inovelli switch LED Bar (B) will turn GREEN (if unsuccessful, the LED Bar will turn RED)
- In addition, if you scroll down under where it says, "Start Z-Wave Exclusion", if successful, the app will show, "Found Devices" and it should list out the Inovelli switch
- Name the device and click, "Save"
- To find your switch, go to the menu and click on, "Devices" -- you should see it listed there.
Gen 1 - On/Off & Dimmer Switches
Please use the directions below for the following products (from left to right: NZW30, NZW30-S, NZW31, NZW31):
Exclusion/Reset
Please follow the below instructions to exclude/reset your Gen 1 On/Off and/or Dimmer Switches (Non-Scene & Scene Versions):
On your Inovelli Switch, press up on the paddle 5x rapidly (within 1-2 seconds)
In addition, the Hubitat app should say that your switch was excluded/removed successfully
Inclusion/Pairing
- Select, "Z-Wave"
In addition, your app will show a device has been added
Click back to the main devices tab and look for your switch!
Fan/Light Switch
Please use the directions below for the following product (LZW36):
You may also need to reference this figure during Exclusion/Reset and/or Inclusion/Pairing:
Figure 1.1
Exclusion/Reset
Please follow the below instructions to exclude/reset your Fan/Light Switch (Red Series):
On your Inovelli Fan/Light Switch, hold down the top of the Light config button (A) while pressing the Light Button 3x (B) - (See Figure 1.1 for reference)
Inclusion/Pairing
Device Driver Installed (search for the correct model. Below are the instructions to include/pair your Fan/Light Switch (Red Series):
- Select, "Z-Wave"
In addition, your app will show three devices have been added
Bulbs
The following section will provide you instructions on how to exclude/reset and include/pair smart bulbs.
CCT & RGBW Bulbs
Please use the directions below for the following products (from left to right: LZW41, LZW42):
Exclusion/Reset
Please follow the below instructions to exclude/reset your CCT and/or RGBW bulbs:
Disconnect power from the bulb
Restore power to the bulb - it should blink twice to confirm the bulb is in exclusion mode
If successful, the bulb should blink once more
NOTE: Sometimes the bulb will just turn to a very dim level -- this means it's been successfully reset
In addition, the Hubitat app should say that your bulb was excluded successfully
NOTE: If this doesn't work, you may need to manually reset the bulb first. Here's how to do it:
Power on/off the bulb 6x (between 0.5 - 2 seconds)
Inclusion/Pairing
Device Driver Installed (search for the correct model). Below are the instructions to include/pair your CCT and/or RGBW Bulbs:
- Select, "Z-Wave"
Restore power to the bulb - it should blink twice to confirm the bulb is in inclusion/pairing mode
In addition, your app will show your bulb
Click back to the main devices tab and look for your bulb!
Sensors
The following section will provide you instructions on how to exclude/reset and include/pair Inovelli sensors.
4-1 Multi-Sensor
Please use the directions below for the following product (LZW60):
Exclusion/Reset
Please follow the below instructions to exclude/reset your 4-1 Multi-Sensor:
On your Inovelli sensor, press the Sensor Button (B) one (1) time
The LED light (on the front) will flash RED indicating the sensor is in inclusion/pairing mode
If successful, the LED light will stop flashing and turn solid RED for 1-2 seconds
If unsuccessful, the LED light will keep flashing and eventually timeout after about 25-30 seconds
In addition, the Hubitat app should say that your sensor was excluded successfully
NOTE: If this doesn't work, you may need to manually reset the sensor first. Here's how to do it:
Hold down the Sensor Button (B) for 5 Seconds
Inclusion/Pairing
Device Driver Installed (search for the correct model). Below are the instructions to include/pair your 4-1 Multi-Sensor:
- Select, "Z-Wave"
On the back of your sensor, press the Sensor Button (B) one (1) time
Once successful, you'll see, "Inovelli 4-1 Sensor" show up on the screen -- feel free to rename it if you'd like!
Plug-In Modules
The following section will provide you instructions on how to exclude/reset and include/pair Inovelli plug-in modules.
Indoor & Outdoor Plug-In Modules
Please use the directions below for the following products (from left to right: NZW36, NZW37, NZW39, NZW96, NZW97):
Exclusion/Reset
Please follow the below instructions to exclude/reset your smart plugs:
On your Inovelli plug, press the middle button 5x rapidly (within 1-2 seconds)
In addition, the Hubitat app should say that your plug was excluded successfully
NOTE: If this doesn't work, you can try the alternate way (this only works for plugs with no logo on the front). Here's how to do it:
Unplug the smart plug from the wall
Plug in your plug and it should auto-exclude
Inclusion/Pairing
Device Driver Installed (search for the correct model). Below are the instructions to include/pair your smart plugs:
- Select, "Z-Wave"
- Select, "Z-Wave"
Plug in your plug and it should auto-include
As always, feel free to reach out with questions!
