This article will share how to include/pair, exclude/remove and/or factory reset your Gen 2 Inovelli switches (please see here for
Gen 1 and for
Fan/Light as the procedures are different). For specific information on how to do this with your specific hub/gateway, please see the links at the bottom of the page.
Including / Pairing Your Switch
Please follow the directions to include or pair your Inovelli switches. Again, for more detailed hub/gateway instructions, please see the links in the bottom section.
- Start the inclusion process on your hub
- Press the config button (top right) 3x until the LED bar pulses BLUE
- The LED bar will flash GREEN if successful
If unsuccessful, the LED bar will turn RED and you may need to try an exclusion or factory reset as per the directions below.
Pro-Tip: If the LED bar is lit up but not pulsing BLUE, then try pressing it faster.
Excluding / Removing Your Switch
Please follow the directions to exclude or remove your Inovelli switches. Again, for more detailed hub/gateway instructions, please see the links in the bottom section.
If unsuccessful, the LED bar will turn RED and you may need to check your Z-Wave Range (hold down the config button for 5 seconds until it turns YELLOW and then let go -- if it's GREEN, you're in range, if it's RED, you're not) or factory reset as per the directions below.
Factory Resetting Your Switch
Please follow the directions to factory reset your Inovelli switches. Please only follow this procedure if the Exclusion method does not work.
- Hold down the config button for 20 seconds until it flashes RED
Hub/Gateway Specific Instructions
The links below will take you to hub/gateway specific instructions. Please note that we do not have instructions for all hubs.
