This article will share how to include/pair, exclude/remove and/or factory reset your Ilumin/Inovelli bulbs. For specific information on how to do this with your specific hub/gateway, please see the links at the bottom of the page.
Including / Pairing Your Bulbs
Please follow the directions to include or pair your Ilumin/Inovelli bulbs. Again, for more detailed hub/gateway instructions, please see the links in the bottom section.
- First, start by turning power off to your bulb (unscrew, flip switch power off, etc)
- Start the inclusion process on your hub
- Restore power to your bulb and it should blink twice (2x) indicating it's in inclusion mode
- The bulb will blink a third time if successful
If unsuccessful, the bulb will just time out and you may need to try an exclusion or factory reset as per the directions below.
Excluding / Removing Your Bulbs
Please follow the directions to exclude or remove your Ilumin/Inovelli bulbs. Again, for more detailed hub/gateway instructions, please see the links in the bottom section.
- Start the exclusion process on your hub
- Restore power to your bulb and it should blink twice (2x) indicating it's in exclusion mode
- The bulb will blink a third time if successful (the bulb will also stay on to a dim mode)
NOTE: If you're looking to switch from one hub to another, please use an Exclusion and not a Factory Reset. You can do the exclusion with either hub (old or new one). Factory Reset should only be used if the exclusion doesn't work or there's no hub/gateway present.
Factory Resetting Your Bulbs
Please follow the directions to factory reset your Ilumin/Inovelli bulbs. Please only follow this procedure if the Exclusion method does not work.
- Power on/off your bulb 6x within 0.5 - 2 seconds
- The bulb will flash twice to confirm it's factory reset
Hub/Gateway Specific Instructions
The links below will take you to hub/gateway specific instructions. Please note that we do not have instructions for all hubs.
