When you install multiple switches in a gang-box, you'll need to remove the heat sink tabs on the side. This can be easily done by grabbing a pair of needle-nose pliers, putting them parallel to the tabs (do not do it perpendicular), wiggling them back and forth until the heat sink tab falls off. Keep in mind that if you do this on a dimmer switch, your maximum wattage will drop.
How to Remove the Tabs
Grab some needle-nose pliers and watch the video below!
Consequences of Removing the Tabs
There are no consequences for removing the tabs on the On/Off switches. However, please note that the maximum wattage will decrease on the Dimmer switches if you remove them. Please see the below specs for both the Red and Black Series Dimmer switches:
Max Wattage: See below -- maximum will vary based on bulb type and whether the heat sink tabs are removed or not
Summary (TLDR) You sure can, however, there are a few steps you should take to make the experience optimal. This is a great solution for people that want to use an alternative wiring scheme or want to have notifications and scene control at both ...
Wiring Diagrams for Gen 1 Dimmer Switches These wiring diagrams should only be used for our Gen 1 dimmer switches, which are shown below -- do not use these for Gen 2! Pre-Requisites Neutral Wire is Required Inovelli switch needs to be installed ...
Wiring Diagrams for Gen 2 Dimmer Switches These wiring diagrams should only be used for our Gen 2 dimmer switches, which are shown below -- do not use these for Gen 1! Pre-Requisites Neutral Wire is NOT Required (But Recommended) Inovelli switch ...
Summary (TLDR) The main difference between our Red & Black Series switches is that the Red Series has everything the Black Series has, plus: Energy Monitoring, Scene Control, and LED Bar Notifications. Red vs Black Series Please see below for the ...
You can use the Black Series On/Off, Red Series On/Off and our Fan/Light Switch on ceiling or exhaust fans. The On/Off switches can only turn the fan on/off and require the fan to be no more than 300W inductive load, while the Fan/Light switch can ...
