How To: Create a Scene From Your Smart Switch | SmartThings
In this article, we'll show you how to create a scene from your smart switch. What this means is that you can double-tap, triple-tap, etc to create various scenes using other smart home products. An example would be: between the hours of 10pm to 6am, if you double-tap down on your switch, you can initiate a bedtime scene where all the lights turn off, doors lock, the garage door is shut and the temperature is set to 68. For the sake of simplicity, we'll show you how to turn off all your lights between the hours of 10pm and 6am.
These are the switches that currently support scene control:
Red Series On/Off (LZW30-SN), Red Series Dimmer (LZW31-SN), Red Series Fan/Light (LZW36)
Directions
Before we get started in setting this scene up, we have to
install a device handler to make sure that SmartThings understands this is a button capable device. Each button correlates to a tap sequence and this is how we'll create scenes. Please see the
Button Mapping Charts for reference.
In this example, we'll show you how to setup a scene where you double-tap down on your light switch (or double-tap on the, "Fan" portion of your Fan/Light switch) and it will turn off all smart lights between the hours of 10pm and 6am for bedtime. Let's begin:
- Open up your SmartThings App to the main page
- Click on the three lines to the left of the screen to open up the menu
- Click on, "SmartApps"
- Press the plus, (+) sign to add a SmartApp
- Select, "Smart Lighting"
- NOTE: Depending on your SmartThings app version, you might need to do the following to find Smart Lighting
- Click "Automations", then "+", then "Add routine". At the "Add routine" screen you scroll down to the bottom to find "SmartApps"
- Select, "New Lighting Automation"
- Click on, "Which devices do you want to control" and select the switches that you want to turn off
- Click on, "What do you want to do?" and select, "Turn Off"
- Next click, "Select Trigger", select, "Button" and click, "Done"
- Click on, "Which button?", select your Inovelli Red Series Switch and click, "Done"
In this example, since we want a double-tap down on your light switch (or double-tap on the, "Fan" portion of your Fan/Light Switch), go to the
Button Mapping Chart for your product and you'll see that a double-tap down (or double-tap on the, "Fan" portion of the Fan/Light) is, "Button 2 Held"
- Click on, "Button Number", select, "Two" and click, "Done"
- Next click, "Button Action", select, "Held" and click, "Done"
- Turn, "Toggle on & off" to off
- Click, "Next" again
- If you want to rename the automation so you can easily remember it, feel free to do so -- if not, then click, "Done"
That's it! Feel free to test your scene.
NOTE: If you'd like to add additional components to your scene, you can create a separate Smart Lighting instance using the same steps above. Or if you'd like to have a SmartApp where you can set all your scenes from, please use
ABC Button Control.
Setting Up Scenes | LZW31-SN | Dimmer - Red Series (Gen 2) | SmartThings
This article will walk you through how to setup custom scenes using your Inovelli Red Series Dimmer Switch and the LZW31-SN Device Handler. Z-Wave Scenes are useful if you want to control multiple smart devices or trigger routines. For example, you ...
Setting Up Scenes | LZW30-SN | On/Off - Red Series (Gen 2) | SmartThings
This article will walk you through how to setup custom scenes using your Inovelli Red Series On/Off Switch and the LZW30-SN Device Handler. Z-Wave Scenes are useful if you want to control multiple smart devices or trigger routines. For example, you ...
How To: Create a Scene with RGBW Bulbs | SmartThings
Overview Our Red Series Switches come with the ability to create scenes directly from the switch. What this means is that you can tap on the switch and trigger a lighting scene such as turning on your smart bulbs to purple for movie night or tapping ...
How To: Create the Ultimate Bedtime Scene | SmartThings
Overview In this article, we'll show you how a single button on a switch can prepare your entire house for bedtime. We'll show you how you can have your house lock all doors, turn off all lights, make sure your garage door is closed, and your ...
How To: Control a Smart Bulb From a Smart Switch | SmartThings
Overview There are a couple reasons why you'd want to control a smart bulb from a smart switch (seems like overkill, we know... but hear us out). Maintain User Experience for Non-Techies: Most people are used to using a light switch to turn on ...
