NOTE: This is a work in progress and features/specs are subject to change. Please see our community thread to stay up to date: https://community.inovelli.com/t/fan-light-switch-project-hurricane-pre-orders-now-open/23 The LZW36 Inovelli Fan + Light ...
Please proceed at your own risk. Bricked switches due to user error will not be replaced nor refunded. If you'd like to mail in your switch to have us do it for you, we're happy to do so. Updating the firmware is a fairly safe & fool proof procedure ...
This article will walk you through the features of the custom device handler and how to install it for optimal usage and advanced functionality on your Inovelli Fan & Light Switch (LZW36) . We promise it's not hard and should take you 5-10 minutes ...
Overview These wiring diagrams should only be used for our fan & light switch and should not be used for anything other than a ceiling fan (ie: no exhaust fans). Pre-Requisites & Comments Neutral Wire is Required at both the switch and canopy ...
Changing Settings at the Switch | Fan + Light - Red Series (Gen 2) | LZW36 Below is a table of setting you can change by using the corresponding tap commands on the switch.
