Change the color of the LED bar on your Inovelli Switches | Hubitat
How To: Change the LED Bar Color | Hubitat
In this article we will go through how to change the LED bar color on your Inovelli Switches.  This will work for the On/Off and Dimmer Switches, Red Series and Black Series.  It's a great option to either match the room you're in or if your kids want a specific color in their own rooms!
Setup
Fortunately, this is a pretty easy thing to do.  Once you have your switch setup into Hubitat and the Device Driver Installed, go to the settings of the device.  Once in the settings, find the LED Strip Color configuration option and simply set the color you want in the drop down.  In the example below, I set it to Cyan.
If you would like to set a custom color, the next configuration box is what you want.  It is titled Custom LED RGB Value.  To find the value you want, look at the chart below to find the number 0-360 you want.  Red is 0, Green is 120 and so on.
Wrapping Up
There you have it.  A very simple way to change the LED bar color on your Inovelli Switches.
As always, don't hesitate to leave any feedback or reach out with questions
    • How To: Change the LED Bar Color | SmartThings
      Summary (TLDR) This article will show you how to change the LED Bar colors on your Inovelli switches. Switches include: Red Series On/Off Switch (LZW30-SN) Red Series Dimmer Switch (LZW31-SN) Red Series Fan/Light Switch (LZW36) Black Series On/Off ...
    • Setup Instructions • Blue Series 2-1 Switch • Hubitat
      REMINDER: This switch is only to be used to control lights (except ballasts or any lights connected to a transformer). Do not use the switches on outlets, fans, or any other inductive load. This is the digital setup instructions for the Blue Series ...
    • Spec Sheet | RGBW (Multi-Color) - A19 Bulb | LZW42
      The LZW42 Inovelli RGBW (Multicolor) Smart Bulb is a Z-Wave enabled light bulb that works with many different hubs and gateways and allows remote control from anywhere in the world. Overview Make: Inovelli (Previously: Ilumin) Model #: LZW42  ...
    • How To: Setup Effects with the Red Series Smart LED Strip | Hubitat
      Intro The process is very similar to setting up a notification on our switch, dimmer, and fan + light using the installed device driver. For example, you can have the strips flash red and blue like police lights when your alarm is triggered. The ...
    • Hubitat Device Drivers
      Device Driver Locations Please see the following locations for each Inovelli Device Driver. Then follow the instructions below! Master Location: https://github.com/InovelliUSA/Hubitat Switches VZM31-SN - 2-in-1 Dimmer (Blue Series Zigbee) LZW30 - ...
