V1.47 - 07/17/2020
Fixed: Bug that when you select the parameter in local config mode and do not edit it. If you long press the config key to save it, it will set to 0.
Fixed: If you are OTA during dimming, that will cause the bulb to flash.
Fixed: multiple switches blink green (like they were excluded)when more than one switch is not on a z-ware network and one of those switches is
Add parameter 51, to enable instant on (ie: disable the 700ms delay). Note, if you disable the delay, it will also disable scene control except for Button 1 (ie: tap up 1x or tap down 1x) and button 7 (config button). All other buttons (2-6) will be disabled.
Added parameter 52. Use to put the switch into "smart bulb" mode. If it set to 1, the power will output maximum % when the dimmer is on. 0 = normal operation, 1 = smart bulb.
V1.43 - 04/11/2020
Fixed: Bug that meter report is sent during dimming resulting in an inaccurate report.
Fixed: Bug that power meter value is 0 when light brightness is 0.
Change the calculation method of parameter 20. Change it from % to KWH. 0=0.01KWH, 10=0.1KWH, 100=1KWH; Modify the range value of parameter 20 to 0~127.
Restart the "Safe guard" time of meter report when the level has been changed. The "Safe guard" timer is to prevent network flooding when device power fluctuates.
V1.41 - 03/28/2020
Fixed Energy & power reporting not being disabled when configuration options are set to 0.
Fixed Power reports flooding network when bulb power consumption fluctuates frequently.
Fixed an issue where the interval time of Central Scene notification is far from the expected value.
Fixed the issue of sending two Meter reports when the device is powered on.
Notifications no longer turning off when user adjusts the level or performs various other actions on the switch.
Change the range of parameter 19 to 0,30-32767 to prevent users from choosing a value that may flood the network.
