Firmware v1.47 (Beta) | LZW31-SN | Dimmer - Red Series (Gen 2)
Update: Firmware 1.47 has been replaced with 1.48 that has more bug fixes and enhancements. Info can be found here:
This page features information regarding the beta firmware for the LZW31-SN that was released on 07/17/2020. This firmware is intended for users that would like to test the fixes and features included in this release before it goes into production. It should be a fairly stable release that fixes several issues.
The attached .otz file is the Z-Wave Chip Upgrade that is target 0 in the Z-Wave PC Controller software.
The Holtek .bin file is the LED bar MCU firmware and is target 1 in the Z-Wave PC Controller software.
V1.47 - 07/17/2020
Fixed: Bug that when you select the parameter in local config mode and do not edit it. If you long press the config key to save it, it will set to 0.
Fixed: If you are OTA during dimming, that will cause the bulb to flash.
Fixed: multiple switches blink green (like they were excluded)when more than one switch is not on a z-ware network and one of those switches is
Add parameter 51, to enable instant on (ie: disable the 700ms delay). Note, if you disable the delay, it will also disable scene control except for Button 1 (ie: tap up 1x or tap down 1x) and button 7 (config button). All other buttons (2-6) will be disabled.
Added parameter 52. Use to put the switch into "smart bulb" mode. If it set to 1, the power will output maximum % when the dimmer is on. 0 = normal operation, 1 = smart bulb.
Previous Releases
V1.45 - 06/22/2020
Removed parameter 7 (Invert Switch) and parameter 10 (Default Level) in local configuration mode. This was to make room on the limited Z-wave 500 chip for the following changes:
Increase the output ratio value on the PWM for better compatibility of Smart Bulbs when in single pole or aux switch mode.
Added the ability to change the LED bar to white when parameter 13 is set to 255.
V1.44 - 05/27/2020
Fixed: Bug when double press the switch immediately after using up/down button causes the LED bar to be incorrect.
Fixed: Holtek firmware was saving data too often causing the bulb to flicker.
V1.43 - 04/11/2020
Fixed: Bug that meter report is sent during dimming resulting in an inaccurate report.
Fixed: Bug that power meter value is 0 when light brightness is 0.
Change the calculation method of parameter 20. Change it from % to KWH. 0=0.01KWH, 10=0.1KWH, 100=1KWH; Modify the range value of parameter 20 to 0~127.
Restart the "Safe guard" time of meter report when the level has been changed. The "Safe guard" timer is to prevent network flooding when device power fluctuates.
V1.41 - 03/28/2020
Fixed Energy & power reporting not being disabled when configuration options are set to 0.
Fixed Power reports flooding network when bulb power consumption fluctuates frequently.
Fixed an issue where the interval time of Central Scene notification is far from the expected value.
Fixed the issue of sending two Meter reports when the device is powered on.
Notifications no longer turning off when user adjusts the level or performs various other actions on the switch.
Change the range of parameter 19 to 0,30-32767 to prevent users from choosing a value that may flood the network.
      Latest Production Version = 1.57.otz and 1.45.bin Latest Beta Version = 1.61.otz and 1.45.bin Summary Please see below for the change-log for the firmware of the Red Series Dimmer Switch (LZW31-SN). This page will be continuously updated with the ...
    • Inclusion / Exclusion | Dimmer - Red Series (Gen 2)
      Summary (TLDR) Please see below for basic inclusion/exclusion information around the LZW31-SN - Red Series Dimmer Switch. For more hub/gateway specialized instructions, please click on the URL's in the third section below to be taken to the specific ...
