This page features information regarding the beta firmware for the LZW31 that was released on 07/17/2020. This firmware is intended for users that would like to test the fixes and features included in this release before it goes into production. It should be a fairly stable release that fixes several issues.
The Holtek .bin file is the LED bar MCU firmware and is target 1 in the Z-Wave PC Controller software.
Links
V1.47 - 07/17/2020
Fixed: Bug that when you select the parameter in local config mode and do not edit it. If you long press the config key to save it, it will set to 0.
Fixed: If you are OTA during dimming, that will cause the bulb to flash.
Fixed: multiple switches blink green (like they were excluded)when more than one switch is not on a z-ware network and one of those switches is
Add parameter 51, to enable instant on (ie: disable the 700ms delay). Note, if you disable the delay, it will also disable scene control except for Button 1 (ie: tap up 1x or tap down 1x) and button 7 (config button). All other buttons (2-6) will be disabled.
Added parameter 52. Use to put the switch into "smart bulb" mode. If it set to 1, the power will output maximum % when the dimmer is on. 0 = normal operation, 1 = smart bulb.
Previous Releases
V1.45 - 06/22/2020
Removed parameter 7 (Invert Switch) and parameter 10 (Default Level) in local configuration mode. This was to make room on the limited Z-wave 500 chip for the following changes:
Increase the output ratio value on the PWM for better compatibility of Smart Bulbs when in single pole or aux switch mode.
Added the ability to change the LED bar to white when parameter 13 is set to 255.
V1.44 - 05/27/2020
Fixed: Bug when double press the switch immediately after using up/down button causes the LED bar to be incorrect.
Fixed: Holtek firmware was saving data too often causing the bulb to flicker.
V1.43 - 04/11/2020
V1.41 - 03/28/2020
