Firmware v1.45 (Beta) | LZW31-SN | Dimmer - Red Series (Gen 2)
Update: Firmware 1.45 has been replaced with 1.47 that has more bug fixes and enhancements. Info can be found here:
This page features information regarding the beta firmware for the LZW31-SN that was released on 06/22/2020. This firmware is intended for users that would like to test the fixes and features included in this release before it goes into production. It should be a fairly stable release that fixes several issues.
The Holtek .bin file is the LED bar MCU firmware and is target 1 in the Z-Wave PC Controller software.
Removed parameter 7 (Invert Switch) and parameter 10 (Default Level) in local configuration mode. This was to make room on the limited Z-wave 500 chip for the following changes:
Increase the output ratio value on the PWM for better compatibility of Smart Bulbs when in single pole or aux switch mode.
Added the ability to change the LED bar to white when parameter 13 is set to 255.
Hubitat Z-Wave Updater Link
Currently Hubitat does not support the upgrade of the Holtek .bin file. There may be some bug fixes or enhancements that may not be preset without updating both targets.
Firmware Change-log: LZW31-SN - Dimmer Switch (Red Series)
Latest Production Version = 1.57.otz and 1.45.bin Latest Beta Version = 1.61.otz and 1.45.bin Summary Please see below for the change-log for the firmware of the Red Series Dimmer Switch (LZW31-SN). This page will be continuously updated with the ...
Spec Sheet | Dimmer - Red Series (Gen 2) | LZW31-SN
Inclusion / Exclusion | Dimmer - Red Series (Gen 2)
Summary (TLDR) Please see below for basic inclusion/exclusion information around the LZW31-SN - Red Series Dimmer Switch. For more hub/gateway specialized instructions, please click on the URL's in the third section below to be taken to the specific ...
Spec Sheet | On/Off - Red Series (Gen 2) | LZW30-SN
