Firmware v1.43 (Beta) | LZW31-SN | Dimmer - Red Series (Gen 2)
Update: Firmware 1.43 has been replaced with 1.44 that has more bug fixes and enhancements. Info can be found here:
This page features information regarding the beta firmware for the LZW31-SN that was released on 05/11/2020. This firmware is intended for users that would like to test the fixes and features included in this release before it goes into production. It should be a fairly stable release that fixes several issues.
The Holtek .bin file is the LED bar MCU firmware and is target 1 in the Z-Wave PC Controller software.
Fixed: Bug that meter report is sent during dimming resulting in an inaccurate report.
Fixed: Bug that power meter value is 0 when light brightness is 0.
Change the calculation method of parameter 20. Change it from % to KWH. 0=0.01KWH, 10=0.1KWH, 100=1KWH; Modify the range value of parameter 20 to 0~127.
Restart the "Safe guard" time of meter report when the level has been changed. The "Safe guard" timer is to prevent network flooding when device power fluctuates.
Firmware Change-log: LZW31-SN - Dimmer Switch (Red Series)
Latest Production Version = 1.57.otz and 1.45.bin Latest Beta Version = 1.61.otz and 1.45.bin Summary Please see below for the change-log for the firmware of the Red Series Dimmer Switch (LZW31-SN). This page will be continuously updated with the ...
Spec Sheet | Dimmer - Red Series (Gen 2) | LZW31-SN
Inclusion / Exclusion | Dimmer - Red Series (Gen 2)
Summary (TLDR) Please see below for basic inclusion/exclusion information around the LZW31-SN - Red Series Dimmer Switch. For more hub/gateway specialized instructions, please click on the URL's in the third section below to be taken to the specific ...
Spec Sheet | On/Off - Red Series (Gen 2) | LZW30-SN
