Firmware v1.43 (Beta) | LZW31 | Dimmer - Black Series (Gen 2)
Update: Firmware 1.43 has been replaced with 1.44 that has more bug fixes and enhancements. Info can be found here:
This page features information regarding the beta firmware for the LZW31 that was released on 05/11/2020. This firmware is intended for users that would like to test the fixes and features included in this release before it goes into production. It should be a fairly stable release that fixes several issues.
The Holtek .bin file is the LED bar MCU firmware and is target 1 in the Z-Wave PC Controller software.
Firmware Change-log: LZW31 - Dimmer Switch (Black Series)
Spec Sheet | Dimmer - Black Series (Gen 2) | LZW31
Inclusion / Exclusion | Dimmer - Black Series (Gen 2)
Summary (TLDR) Please see below for basic inclusion/exclusion information around the LZW31 - Black Series Dimmer Switch. For more hub/gateway specialized instructions, please click on the URL's in the third section below to be taken to the specific ...
Firmware v1.44 (Beta) | LZW31 | Dimmer - Black Series (Gen 2)
Update: Firmware 1.44 has been replaced with 1.45 that has more bug fixes and enhancements. Info can be found here: https://support.inovelli.com/portal/kb/articles/firmware-v1-45-beta-lzw31-dimmer-black-series-gen-2 This page features information ...
