Firmware v1.36 (Beta) | LZW36 | Fan + Light - Red Series
This page features information regarding the beta firmware for the LZW36 that was released on 08/14/2020. This firmware is intended for users that would like to test the fixes and features included in this release before it goes into production. It should be a fairly stable release that fixes several issues.
Please proceed at your own risk. Bricked switches due to user error will not be replaced nor refunded. If you'd like to mail in your switch to have us do it for you, we're happy to do so (NOTE: You will be responsible for to/from shipping costs and we will not provide any temporary switches -- also, estimated time for completion is 2-3 weeks upon receipt).
Links
V1.36 - 08/14/2020
Fixed: Issue of Z-wave switch losing communication with fan module under certain scenarios.
Add parameter 51, to enable instant on (ie: disable the 700ms delay). Note, if you disable the delay, it will also disable scene control except for Button 1 (ie: tap up 1x or tap down 1x, held & released) and button 6, 7, 8, 9 (level up / down buttons). All other scenes will be disabled.
Spec Sheet | Fan + Light - Red Series (Gen 2) | LZW36
NOTE: This is a work in progress and features/specs are subject to change. Please see our community thread to stay up to date: https://community.inovelli.com/t/fan-light-switch-project-hurricane-pre-orders-now-open/23 The LZW36 Inovelli Fan + Light ...
How To: Update your Fan/Light Switch Firmware | Hubitat
Please proceed at your own risk. Bricked switches due to user error will not be replaced nor refunded. If you'd like to mail in your switch to have us do it for you, we're happy to do so. Updating the firmware is a fairly safe & fool proof procedure ...
Firmware Change-log: LZW31-SN - Dimmer Switch (Red Series)
Latest Production Version = 1.57.otz and 1.45.bin Latest Beta Version = 1.61.otz and 1.45.bin Summary Please see below for the change-log for the firmware of the Red Series Dimmer Switch (LZW31-SN). This page will be continuously updated with the ...
Installation & Setup | LZW36 | Fan + Light Red Series (Gen 2) | SmartThings
