This page features information regarding the beta firmware for the LZW30 that was released on 07/06/2020. This firmware is intended for users that would like to test the fixes and features included in this release before it goes into production. It should be a fairly stable release that fixes several issues.
Add parameter 51, to enable instant on (ie: disable the 700ms delay).
Added the LED color, "White" when parameter 5 is set to 255.
Firmware Change-log: LZW31 - Dimmer Switch (Black Series)
Spec Sheet | Dimmer - Black Series (Gen 2) | LZW31
Firmware v1.16 (Beta) | LZW30 | Switch - Black Series (Gen 2)
Update: Firmware 1.16 has been replaced with 1.17 that has more bug fixes and enhancements. Info can be found here: https://support.inovelli.com/portal/kb/articles/firmware-v1-17-beta-lzw30-switch-black-series-gen-2 This page features information ...
Firmware v1.17 (Beta) | LZW30 | Switch - Black Series (Gen 2)
This page features information regarding the beta firmware for the LZW30 that was released on 05/01/2020. This firmware is intended for users that would like to test the fixes and features included in this release before it goes into production. It ...
How To: Update your Dimmer Switch Firmware | Hubitat
Please proceed at your own risk. Bricked switches due to user error will not be replaced nor refunded. If you'd like to mail in your switch to have us do it for you, we're happy to do so. Updating the firmware is a fairly safe & fool proof procedure ...
