Firmware v1.19 (Beta) | LZW30-SN | Switch - Red Series (Gen 2)
This page features information regarding the beta firmware for the LZW30-SN that was released on 07/06/2020. This firmware is intended for users that would like to test the fixes and features included in this release before it goes into production. It should be a fairly stable release that fixes several issues.
The attached .otz file is the Z-Wave Chip Upgrade that is  target 0 in the Z-Wave PC Controller software.
Add parameter 51, to enable instant on (ie: disable the 700ms delay). Note, if you disable the delay, it will also disable scene control except for Button 1 (ie: tap up 1x or tap down 1x) and button 7 (config button). All other buttons (2-6) will be disabled.
Added the LED color, "White" when parameter 5 is set to 255.
      Latest Production Version = 1.48.otz and 1.41.bin Latest Beta Version = 1.56.otz and 1.44.bin Summary Please see below for the change-log for the firmware of the Red Series Dimmer Switch (LZW31-SN). This page will be continuously updated with the ...
    • Firmware v1.17 (Beta) | LZW30-SN | Switch - Red Series (Gen 2)
      This page features information regarding the beta firmware for the LZW30-SN that was released on 05/01/2020. This firmware is intended for users that would like to test the fixes and features included in this release before it goes into production. ...
