Firmware v1.17 (Beta) | LZW30 | Switch - Black Series (Gen 2)
This page features information regarding the beta firmware for the LZW30 that was released on 05/01/2020. This firmware is intended for users that would like to test the fixes and features included in this release before it goes into production. It should be a fairly stable release that fixes several issues.
Update: Firmware 1.17 has been replaced with 1.19 that has more bug fixes and enhancements. Info can be found here:
Fixed: multiple switches blink green(like they were excluded)when more than one switch is not on a z-ware network and one of those switches is
excluded.
Fixed: when the load is off, setting parameter 3(auto off time) problem. Sometimes the timer would be incorrect the first time the load turned off.
Fixed: when the parameter 3 is set from non-zero to zero, it is immediately closed if the load is on.
Add parameter 13, for some special load types. Can be used in certain 3-way dumb switch setups where the load is confusing the switch as to which state it should be in.
Parameter 13
Default: 0
0: Detect Load Type.
1: Manually set for special load type.
Firmware Change-log: LZW31 - Dimmer Switch (Black Series)
Spec Sheet | Dimmer - Black Series (Gen 2) | LZW31
Firmware v1.16 (Beta) | LZW30 | Switch - Black Series (Gen 2)
Update: Firmware 1.16 has been replaced with 1.17 that has more bug fixes and enhancements. Info can be found here: https://support.inovelli.com/portal/kb/articles/firmware-v1-17-beta-lzw30-switch-black-series-gen-2 This page features information ...
How To: Update your Dimmer Switch Firmware | Hubitat
Please proceed at your own risk. Bricked switches due to user error will not be replaced nor refunded. If you'd like to mail in your switch to have us do it for you, we're happy to do so. Updating the firmware is a fairly safe & fool proof procedure ...
