Firmware v1.17 (Beta) | LZW30-SN | Switch - Red Series (Gen 2)
This page features information regarding the beta firmware for the LZW30-SN that was released on 05/01/2020. This firmware is intended for users that would like to test the fixes and features included in this release before it goes into production. It should be a fairly stable release that fixes several issues.
Update: Firmware 1.17 has been replaced with 1.19 that has more bug fixes and enhancements. Info can be found here:
The attached .otz file is the Z-Wave Chip Upgrade that is target 0 in the Z-Wave PC Controller software.
Fixed: multiple switches blink green(like they were excluded)when more than one switch is not on a z-ware network and one of those switches is
excluded.
Fixed: when the load is off, setting parameter 3(auto off time) problem. Sometimes the timer would be incorrect the first time the load turned off.
Fixed: when the parameter 3 is set from non-zero to zero, it is immediately closed if the load is on.
Add parameter 13, for some special load types. Can be used in certain 3-way dumb switch setups where the load is confusing the switch as to which state it should be in.
Parameter 13
Default: 0
0: Detect Load Type.
1: Manually set for special load type.
    • Firmware v1.19 (Beta) | LZW30-SN | Switch - Red Series (Gen 2)
      This page features information regarding the beta firmware for the LZW30-SN that was released on 07/06/2020. This firmware is intended for users that would like to test the fixes and features included in this release before it goes into production. ...
      Latest Production Version = 1.48.otz and 1.41.bin Latest Beta Version = 1.56.otz and 1.44.bin Summary Please see below for the change-log for the firmware of the Red Series Dimmer Switch (LZW31-SN). This page will be continuously updated with the ...
